It is currently Wed May 20, 2026 5:53 am
PostPosted: Thu Jun 05, 2008 12:03 pm
Hi all I found a 833 in a late '87 D150, but it has a externally splined drive shaft, is this normal ? I found these number on the left side (drivers side) C15154
STD
and on the right (pass) *stamping* then 3544
C15154
Is this a decent 4spd to use in a F-body ? or should I look for F-body specific 4spds ?
-Mike
PostPosted: Tue Jun 10, 2008 12:46 pm
Long shaft 833OD probably. Bolts into E and B bodies. There is a way to make the shift linkage work in an A body. Someone did it on Moparts. Never did show any pics.
PostPosted: Tue Jun 10, 2008 7:41 pm
Someone here or maybe it wa son the now defunct other /6 site had made that long tail OD trans swap-to-A-body (68 Cuda I believe) and has posted pix here and there. I did the opposite; put a short tail one into a 79 D 100.
 Post subject: Dave...
PostPosted: Tue Jun 10, 2008 7:49 pm
It was Dave Clements and he did it in a Barracuda... it's part of the 4 speed Article...
 Post subject: See this...
PostPosted: Sun Jun 15, 2008 2:37 pm
Car Model: 1974 W100; 72 Dart
..sixpac showed it to me:
http://www.bigblockdart.com/techpages/abconv.shtml
sb
