It is currently Sat Jul 18, 2026 12:24 am
Post new topic  Reply to topic  [ 27 posts ]  Go to page Previous 1 2
 Post subject: Re: motor plates?
PostPosted: Mon Jun 09, 2008 10:19 pm
Has anyone gone through the trouble of doing a nice set of CAD'd motor plates for the /6? I'd like to have a motor and mid plate on my open wheel car.
I'd also like to talk to some of the guys using a dry sump system.
Thanks!
I make motor plates for slant 6. Go to www.pacefabrication.net and check out "Products" and Cars & Projects. See motor plate installation on a slant 6 Demon
MoparEdd
PostPosted: Mon Jun 09, 2008 10:26 pm
I would like at least one set, possibly two. Let me know when you are ready to make them; when you need $, etc.
Check out this website for pictures and prices.
If any questions...email me moparedd
PostPosted: Mon Jun 09, 2008 10:31 pm
[quote="sergio"]We are in the process of making several for some west coast sl6 racers,for now only for 225s. We can sell these for $115 lincludes the frame brackets,water pump hole or remote, we are also supplying a bracket that bolts to the alt. bracket bolt holes for additional bracing. If interested see wwwpacefabrication.net
PostPosted: Thu Jun 12, 2008 7:11 am
These engine plates are a 'work of art"..if you have ever seen Edd's work (or his new car..Check out his website for start/finish photos) you will know you are getting the best engineered products at a very affordable price. I run one on my new 1962 Valiant and they fit perfect. Go to PACEFABRICATION.NET and check out his slant6 "goodies"
PostPosted: Thu Jun 12, 2008 4:50 pm
I have one on my 62 Valiant.......and love it.
It came from Ed.
Andrew
Wife's: 64 Valiant
PostPosted: Wed Jun 25, 2008 8:31 pm
Hey Tim...I have motor plates ready for shipping. Do you want one with the water pump provisions or without? see www.pacefabrication.net.
or email me mopareddpacefab@aol.com
PostPosted: Wed Jun 25, 2008 8:37 pm
We can make them any time,allow about 10 days for delivery,we need a little info about the chassis. Prymarily the crank centerline as it relates to your chassis,and if you have moved the engine around or a chassis car frame rail width,etc. If interested call the # listed above to find otu any other pertinent info required. Thanks , we are also narrowing 8 3/4 rear ends to your specs ,we have several cores,call for pricing and details,thank you.
Hi: I have motor plates ready for shipping...with and without water pump
provisions. check my web at www.pacefabrication.net or email me with your phone number and I will contact you. Mopareddpacefab@aol.com
PostPosted: Thu Nov 20, 2008 8:02 pm
I thought a plate would be the ticket for swapping a slant 6 into my '49. Sent Edd specs and photos and he replied couldn't do it for my application. Not sure why. Anyone else have another source?
PostPosted: Fri Nov 21, 2008 4:47 am
That is very odd. In theory, he could cut out the needed holes for the engine in the middle of a 4x8 sheet and let you cut to fit your application.
Surprising since he has basically advertised his work in every reply :roll:
Chris'
Autobody
Restoration
Service
PostPosted: Fri Nov 21, 2008 4:47 pm
Yea- I can't help but think it was a misunderstanding. I have a message out to him now. We'll see. The old flathead in my photo is coming out. The slant six is going in.
PostPosted: Fri Nov 21, 2008 6:12 pm
If you want to try and make your own all you need to do to start is trace out a water pump gasket on some cardboard and make yourself a template. Cardboard is a lot cheaper to experiment with than aluminum. :lol:
 Post subject: Plate
PostPosted: Fri Apr 22, 2011 7:59 pm
I picked one up from EDD while MATS..... So far so good.... I will try to finish the install tomorrow....Need a piece of angle iron to finish it off, so I can attach it to the frame rails.
Again Thanks Edd!!!!
BIG T
1967 Dart "Six Shooter"
Girlfriend Rhonda... 66 Valiant
Image[/URL]
