It is currently Mon Nov 23, 2026 12:58 pm
PostPosted: Thu Jun 12, 2008 6:06 pm
Does 80" sound right for the length of a speedometer cable for a '73 4-door Dart? That's the only lemgth I've been able to locate.
Thanks!
________
jailbroken
PostPosted: Thu Jun 12, 2008 7:15 pm
Sounds a little on the long side, to me. Believe you're after a 68" cable such as NAPA Balkamp #615-1659.
PostPosted: Fri Jun 13, 2008 7:42 am
When I installed all aftermarket gauges in my 73 Swinger, I had to get a new speedo cable with the threaded end (not clip) for the speedo (a 66 cable worked).
All I could find were 80" cables. It loops around my master cylinder, but works fine. NAPA didn't carry the cables I needed, but in my search I did see that NAPA had the proper length cable for a 73 with the clip end, as Dan said.
Anyway, depending on how soon you need it, I still have my old one you can have. I see you are in Chico. I live in Redding.
PostPosted: Fri Jun 13, 2008 6:14 pm
Thanks guys! Turns out that our local NAPA had the 68" cable (or can get it in one day), so I bought it. Hopefully 68" is right.
Update: It fit perfectly!
________
Mercedes-Benz 380 history
PostPosted: Thu Aug 21, 2008 6:43 am
Would this be the same speedo cable for a 63 Valiant as well?? 68"??
Linder Tech.com
Bubba's Trailer Park
PostPosted: Thu Aug 21, 2008 10:21 am
No, the '60-'65 transmissions take a totally different cable. What transmission are you running?
