It is currently Mon May 25, 2026 7:41 pm
 Post subject: Edelbrock IAS shocks
PostPosted: Thu Jun 12, 2008 8:05 pm
Has any one tried these shocks on their 70 to 74 Dart?
If so, will they settle a stiff ride?
I have sway bars and extra stiff leafs......ESPO 6 leaf.
I am running Monroe gas shocks and they are pretty harsh at times.
Thanks!
PostPosted: Fri Jun 13, 2008 5:47 am
Not quite the same but i have them on my 1993 Ranger pickup. I didnt think they felt any better than the stock shocks except that they werent worn out, but the Ranger being 20 years newer handles pretty good when it was new.
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
PostPosted: Fri Jun 13, 2008 6:45 am
Hi Ted,
I have KYBs and 6 Leaf springs on my '68 Dart 270.
I can sympathize with the "harsh ride" comment. Bumpy roads sometimes feel like I'm driving a go-cart.
-Mac
PostPosted: Fri Jun 13, 2008 7:28 am
The Edel IAS shocks are head and shoulders above stock replacements, or the KYBs. I've run both on two A-bodies. Spend the cash for the IAS and you will get better handling and a nicer ride than KYBs.
PostPosted: Fri Jun 13, 2008 10:26 am
Lou,
That is what I was looking for. My Dart weighs 3280 pounds. I wasn't sure if the IAS were designed for handling that weight with the stiffer suspension components.
Sounds like they should be a great solution to the ocassional rough ride.
PostPosted: Fri Jun 13, 2008 10:50 am
The reports from Mopar handling guys who have talked to Edel said that you should be able to handle twice the stock spring rate, so no problems for you. I have 0.920" TBs on the '64, which are about 60% higher than stock, and they are fine.
PostPosted: Mon Jun 16, 2008 11:59 pm
I received a set of koni shock for the cuda as a test - but the edelbrock units looks like a good option as well - comment?
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Tue Jun 17, 2008 7:18 am
Bang for the buck - get the IAS's.
Best shocks - hard to argue with Konis. (although I've never tried them)
PostPosted: Tue Jun 17, 2008 7:47 am
The IAS rears for an A body are the same as Ford Explorer rears. Summit had them on sale for $20 last year......
PostPosted: Thu Jun 19, 2008 8:29 pm
What were they called? How do yo know they were Edelbrock's?
What is catalog the part number?
Thanks,
