It is currently Mon Jun 15, 2026 1:55 am
 Post subject: I Want More Cubic Inches
PostPosted: Tue Jun 17, 2008 9:34 am
i want more cubic inches and i am going .045 over and i don't want to stroke my 225 but i am going for the high compresion 2.2 liter pistons and 198 rods eny other ways to get cubes
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Tue Jun 17, 2008 9:54 am
I know of 3 ways to increase displacement...
- Larger cylinder bore
- More crankshaft stroke
- Get a different (larger displacement) engine to start with. :wink:
The "long rod" 225 does not increase displacement anymore then the .045 over bore provides.
PostPosted: Tue Jun 17, 2008 9:55 am
EDIT: I agree with whatever Doc says... :oops:
A few cubes wont give alot more power so if this isnt a race engine I wouldn't bore more then needed to get fresh cylinder walls. However If you've decided to go big bore I think go could go .080-.100 over if your walls are thick enough.. There's a lot of info on this board if you use the search-engine.
Good luck,
Rob / Norway
Rob,
Dart -74 4dht.
PostPosted: Tue Jun 17, 2008 11:37 am
i want a sceraming slant six to teach some local cameros about speed
PostPosted: Tue Jun 17, 2008 12:17 pm
You could go for 1mm oversize 2.2 pistons for 0.085" overbore. This is safe on almost any Slant block.
Best place to spend money and time is the cylinder head. Huge gains can be had here. I repeat - do no skimp on the headwork. Find a good head porter, or have Mike Jeffrey in Nebraska or one of the Drake's buddies in Charlotte do the porting. It is worth a lot.
PostPosted: Tue Jun 17, 2008 1:01 pm
well head wise i am going 4 oversized valves, i got a good local machinest and he has ben building engines for a very long time, and dosent the 2.2 liter pistions increace the comprestion ratio
PostPosted: Tue Jun 17, 2008 3:54 pm
I do that all the time with a 4 cylinder Neon; it's not all about bigger.
It's about power/weight and tuning/prep.
Besides, who cares what Camaro people think?
1975 Duster 225, same thing in a van.
Also a bunch of Neons.
PostPosted: Tue Jun 17, 2008 4:15 pm
offset grind the crank
PostPosted: Tue Jun 17, 2008 4:44 pm
Spray it. :shock:
Leave the Camaro people alone. They are unteachable to start with. :lol:
PostPosted: Tue Jun 17, 2008 6:00 pm
are you talkin nos??? :D
PostPosted: Tue Jun 17, 2008 8:40 pm
whoa, my best bud had a beautiful 69 camaro with a easy 400 horsey small block. Granted he gives me plenty respect for the slant six and always wanting a challenge. However, both of us realise that for the money and time the 340 I have in the shop will be the next motor to spank any camaro that has any respectful motor in it. Even with a full boosted motor I will be reaching deep into my pockets.... might want to plan on just building a nice motor. I don't know what your expirence or bank account reached to, but trust me a big cube slant six isn't the answer.
PostPosted: Wed Jun 18, 2008 5:58 am
i think that if you could match up a well built slant 6 with a lightweight car you could beat a camero but that takes money and time and i got a little bit of both (more time than money)
PostPosted: Wed Jun 18, 2008 11:04 am
Unteachable like the mustang lot :twisted:
Look at what Doc did with his dart a while ago.....
A big cube ala doc 260 would be nice but the cost for the gain wories me
I would rather spend the cash on the ignition head cam headers and induction - in that sequence
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Wed Jun 18, 2008 1:18 pm
well i have looked into electronic igniotion i got a super six intake and headers and i found a cam and i know a very good machineist
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
