It is currently Thu May 14, 2026 3:20 pm
PostPosted: Mon Dec 16, 2002 1:04 am
I need to pickup a LCA for the 74 duster. On the 73-76 A bodies was there a difference between disc v drum LCA, or was it just the ball joint. I have discs and want to know if it matters which I get? TIA
 Post subject: no diff, just ball joint
PostPosted: Mon Dec 16, 2002 10:46 am
Just as you said - LCAs are the same but use different balljoints.
