It is currently Mon Oct 12, 2026 6:29 pm
PostPosted: Wed Jun 18, 2008 2:08 pm
mine just went :(
http://www.partsamerica.com/ProductList ... or=Starter
the ac delco one seems best but maybe a remanufactured one is better im nto sure
87 d150 2bbl carb 225
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
89 f450 diseal 4x4 dually 5sp
PostPosted: Wed Jun 18, 2008 2:17 pm
"Remanufactured" parts are junk. You will wind up unhappy sooner or much sooner ("lifetime warranty" means you get to spend your lifetime replacing the part again and again under warranty...what a deal! :shock:)
If you have the time, take your starter to a local auto electrical (starter/alternator) rebuilder and have it bench-rebuilt. The resultant part will be of much higher quality and reliability than the junk from the parts store.
If you don't have the time to wait around for a rebuild, then hit a wrecking yard for a starter from an '89-'01 Dodge Ram or Dakota pickup or (full-size) van with 3.9 V6 or 5.2 or 5.9 V8. This is the high-speed mini-starter people are always talking about. It'll drop right in place on your slant-6. A used part of this type will still be much preferable to a "remanufactured" piece from the parts store.
And don't be fooled by "100% new" verbiage applied to parts store starters and alternators. Sure, the components are 100% new...that is, they're 100% new counterfeit knockoff garbage from China. :roll:
PostPosted: Wed Jun 18, 2008 2:49 pm
ok so i should get my starter rebuilt i think its from a 80 maurder or somthing not a truck.. it came off the engine because the one that it came with was some new nock off and it blew
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
PostPosted: Wed Jun 18, 2008 2:58 pm
is this what you were reffering 2 dan mini high torque starter it says its compatible
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0249944846
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
PostPosted: Wed Jun 18, 2008 3:10 pm
The one you've linked to on eBay is one of the Chinese knockoffs. The real late-type starters look just like it, but aren't made out of compressed Chinese 7-year-old political dissidents :roll: . When buying starters like this, skip the ones that lack a Chrysler/Denso/Nippondenso part ID tag or plate on them. Also, the round motor housing on the real ones is painted a light silver; this one you're showing us is plated rather than painted, and other fakes have other colours of paint (green seems popular at the moment).
There's no truck vs. car difference in the starter motors such as your '87 came with, so even if the one you have wasn't original to the truck, it's OK.
Also, I've fixed your eBay link. Please never post eBay's long-long item links; they screw up the page view for the entire thread. eBay link posting guidelines are in this post; following them will make things a lot easier for everyone who wants to read your post/thread, thanks.
PostPosted: Wed Jun 18, 2008 3:50 pm
Is the mini starter from the above mentioned Dodges in wrecking yards lighter than the stock Slant starter?
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
PostPosted: Wed Jun 18, 2008 4:08 pm
Yes, much lighter.
PostPosted: Wed Jun 18, 2008 4:10 pm
I recently did that starter swap, on my 66 Valiant. The original starter weighed 14 lbs, and the Nippondenso starter was 7 lbs.
I am getting ready to replace the stock 39 amp alternator, with the 90+ amp Nippondenso unit from a 89 Dakota. The nippondenso unit is 13 lbs compared to 14 lbs for the original.
PostPosted: Wed Jun 18, 2008 5:29 pm
so if i was to order this nippondenso starter it from here direct /here
would that be a good choice
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
PostPosted: Wed Jun 18, 2008 6:17 pm
No, this what you're pointing at is a "remanufactured" starter — see above — and it is the wrong one, at that. The one you need has a nose cone. Looks like you looked up the wrong year and the wrong engine.
PostPosted: Wed Jun 18, 2008 6:32 pm
ya i noticed that it was a mistake so ill just find some old dakota i can get under and get one
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
PostPosted: Thu Jun 19, 2008 2:53 pm
Dude, this is your best bet. And you can't beat the price!!! Im running 3 junker mini's on my car's and they have been very reliable for the past 5 years and counting.
PostPosted: Thu Jun 19, 2008 8:52 pm
I love the junkyard mini Dakota starter. Its very reliable, lite and cranks about twice as fast. Most Dodge/Plymouths that I see crank for a few seconds before they fire up. Not mine. Just touch the key and it comes to life. I contribute it to the fast cranking speed.
 Post subject: Cheese with that?
PostPosted: Tue Jun 24, 2008 8:22 am
The mini's lack the familiar Mopar whine on startup that is part of the experience, along with rotted fenders where the water pools on the flat spot. :(
 Post subject: Re: Cheese with that?
PostPosted: Tue Jun 24, 2008 8:54 am
Yup. That's why I use the Chrysler-built starters rather than the miniature ones. But I have to be honest about it; the miniature ones are better in every quantifiable way: lighter, stronger, etc.
