It is currently Thu May 28, 2026 11:25 am
 Post subject: helppp
PostPosted: Thu Jun 19, 2008 4:31 pm
ok ur gunna think im dumb. butt here we go
i have a 64 dart with a slant six three on the tree
i recently acguired a 318 wideblock with a 727.
my question wat will i have to buy to get the 318 onto the three speed? will the slant six bell housing and flywheel work? please help.
PostPosted: Thu Jun 19, 2008 7:23 pm
Nothing from the Slant will work.
 Post subject: Yep!
PostPosted: Thu Jun 19, 2008 7:58 pm
And believe me you'll be thankful for it!
I hope your cutting torch and welding skills are up to par, because you'r gonna be using them... (that and a showhorn, pry bar... and the costco size bucket of KY to force that fat block into the narrow engine bay)...
The 318 poly uses many of the parts the 1967 LA block 318 uses ... but its a bit bigger and heavier, and it doesn't have as many easy to get parts...
Now for the cost of your conversion you could get a gas mileage getting performance slant that will probably equal that 318...
PostPosted: Fri Jun 20, 2008 10:34 am
I think exhaust manifolds (or lack of any that fit this application) is the "show stopping" issue to overcome.
PostPosted: Sat Jun 21, 2008 2:08 pm
will the bell housing not bolt up eitherE?
PostPosted: Sat Jun 21, 2008 2:39 pm
Nope, the bellhousings and proposed motors are different.
PostPosted: Sat Jun 21, 2008 6:15 pm
Like all auto manufacturers bellhousings usually are grouped by an engine
type/family/application...
Mopar kept things real simple:
slant-6 only
A/LA Engine (318 poly, and all 273-360-5.9 Magnum engines)
Big Block (350-440)
(and later the Jeep 4.0L-AMC I-6 family)
You will have to have an adaptor to go from one to the other, or the proper tranny... the slant six tranny (if an auto) would not like the brutal abuse the 318 would put on it anyway.
PostPosted: Sat Jun 21, 2008 7:24 pm
slant-6 only
Big Block (350-440)
Mopar is actually a nightmare compared to Chevy.
4 cyl. Nova motor, straight and V-6 cylinder, small block, pig block. Same bolt pattern. :?
 Post subject: Lol...
PostPosted: Sat Jun 21, 2008 7:32 pm
But definately much nicer than Ford! (Lemme see... the 351C is a small block, but the extended deck 400C only bolts to the 429/460 pig block tranny... and which pig block is it 427/428 or a 429/460?)
:lol:
 Post subject: Re: Lol...
PostPosted: Sat Jun 21, 2008 9:06 pm
:lol:
If I recall, correctly, there is even a difference in the bolt pattern of the 289 or 302, depending on the year.
PostPosted: Sat Jun 21, 2008 11:24 pm
Isn't the 318 wideblock also supposed to take the chrysler firepower hemi heads? If so I'd grab some of those parts and make that 318 poly a decent motor instead of an iron lung.
PostPosted: Sun Jun 22, 2008 12:30 am
:lol:
The split was in the 289 at 1964 IIRC. 4 bolt or 5 bolt pattern.
221,260 and 4 bolt 289 go together.
5 bolt is the same as 302/351 C&W.
331,352,360,390,406,427, and 428 were the same.
351-M/400, 429, and 460.
Easy as cake, right?
Unless you want to get into all the different Mercury/Lincoln/truck ones too. :lol: :lol: :lol: :lol:
