It is currently Sun Dec 28, 2025 6:53 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Tue Jun 24, 2008 10:54 pm
Doc sent me anouther dist to try,ALOT better ,set it at 12 initial,30 all in,peppier and all around better,will be adding 91 octange to the 5 gals of 114 i have in it now,,,de tuneing the fuel to tune,,,,,have 16 inch of vacume at idle,All pinging gone,hopeing it wont come back,would like to be able to run 91 pump gas with a bit of 112 mixed,10.7 Mark
PostPosted: Tue Jun 24, 2008 11:04 pm
Also amazed at how quickly a 600 Holley can drain a 10 gallon tank as you are testing and tuneing.mark
PostPosted: Wed Jun 25, 2008 5:46 am
The new distributor should help a lot, the first one was set-up to give 30-32 degrees total at 10-12 initial. Currently we are seeing 36+ at 2800 RPM... way to much, especially with the high stall converter (4000 stall and from what Mark describes, the converter is getting every bit of that) Bottom line, it's over-advanced right when you hit the throttle.
The distributor I just set him is much shorter on mechanical advance (12 degrees) and I slowed down the rate a little... I bet that will fix most of the pinging issues, as long as some race fuel is mixed-in. Good thing this is "mostly" a race car. :twisted:
We knew going into this build that the cam is too small for the compression combo. but we were working with an engine and a pile of parts Mark already had. The decision was to get a running engine into the car so the rest of the project could progress, rather then start over and build a motor from scratch.
By running the lash down as tight as possible, some careful distributor recurving and the "right" mix of race fuel, we should get the car down the 1/4 mile with-out melting the pistons out of it.
In hind sight, I should have used a thicker head gasket on this engine... we used a .020 shim gasket just to make sure it sealed... if we decide to spray it.
Hi Doc
What kind of CR should one aim for with the erson 270
Regards
Fanie Gerber
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Wed Jun 25, 2008 5:53 am
Fanie,
I would aim for 9.5:1 for pump gas.
PostPosted: Wed Jun 25, 2008 7:28 am
Lou beat me to it... 9.5 is about right for that cam.
PostPosted: Wed Jun 25, 2008 11:12 am
Thanks Guys - now whom to bribe to buy me one since the SOB website dont list mopar cams.... :(
Regards,
Fanie Gerber
PostPosted: Sat Jun 28, 2008 1:06 am
Been playing with car after Doc sent me new dist,probably got octange down to 100,guestemate, NO pinging and this car feels twice as fast as my 18 second slant,,,so my math tells me i have a 9 second car!,,bet its closer to 15+ but it feels like 9s to me,oil leak away from happyness.
mark
PostPosted: Sat Jun 28, 2008 10:51 am
Drag it to Samoa and we can run for Pinks... :P :wink:
