It is currently Mon Jun 15, 2026 7:11 am
 Post subject: Holley 2bbl
PostPosted: Wed Jun 25, 2008 5:51 pm
Would a holley 2bbl off of a 79 merc bobcat be the 350cfm staged 2bbl we are looking for as a step up from a bbd?
PostPosted: Wed Jun 25, 2008 6:39 pm
No, the would be a Holley/Weber 5200 type. Having tried one on a mildly modified 225 I can say that it's too d@mn small. Two of them would probably work though. :)
Almost forgot to mention I had to drill the idle jet to get my engine to idle. The stock idle circuit was lean on a 2.3L, it was hopeless on a 3.7L.
PostPosted: Wed Jun 25, 2008 9:35 pm
Is this what you're looking for 70valiant??
http://cgi.ebay.com.au/holley-carby-350 ... dZViewItem
62 Valiant, 225cid Slant 6/PB 904 with lots of good bits
http://www.moparmarket.com/readersrides ... user=SV162
 Post subject: Yep...
PostPosted: Wed Jun 25, 2008 9:41 pm
0-80120... that's a Holley 350 cfm staged two barrel...pretty rare carb nowadays...
The only drawbacks I've found to this carb so far are:
1) the 'staging' is mechanical ... so you bend the rod and find the best 'tip in' point
2) The bores are the same size as the Holley 500 cfm normal 2 barrel... so on a super six manifold it tend to be like a 1 barrel, you push on the acc. pedal and the vacc. reading takes a nice 'dip'... I think using it with an adaptor plate on an Offy manifold would be a better 'matchup', plenum and manifold-wise...
Users browsing this forum: Amazon [Bot], ceej and 3 guests
