It is currently Mon Nov 16, 2026 5:34 pm
PostPosted: Sat Jun 28, 2008 1:11 pm
....im more of a picture guy but dont you guys mean the float bowl gasket and screws that hold the other half of the bowl to the core?
BTW does anyone have an explosive diaphram of the 64-3114?
NEVERMIND the three screws, i get it Ill try to fix that, so just tighten those up?
71 dodge dart custom
1988 Honda Civic ((Because racecar))
2005 VW Jetta
1963 AMC Rambler American 440
PostPosted: Sat Jun 28, 2008 1:33 pm
With a lock washer or star nut or you will be doing it next week.
Do a search on this site for the Holley 1920 repair guide. SL6 Dan has posted it many times. It is a .jpg manual about 15 pages long.
If you can't find it send me your email. I will send you a copy.
PostPosted: Sat Jun 28, 2008 3:20 pm
Well a friend told me that the problem may be the fact that i dont have a spacer for the Holley 1920 anymore, is it possible that a lack of a 1/2 inch spacer can trigger a very large vaccuum leak?
2005 VW Jetta
PostPosted: Sat Jun 28, 2008 4:29 pm
You do need to be running the correct (3/8" thick) spacer gasket, or you'll have heat and linkage related problems, but I don't think that's causing your whistle.
PostPosted: Sat Jun 28, 2008 5:14 pm
doesnt hurt to try
2005 VW Jetta
PostPosted: Sun Jun 29, 2008 4:19 pm
Does that mean you were running it with out a gasket?
Or just with out the 3/8" thick one?
PostPosted: Mon Jun 30, 2008 4:53 pm
just with out the 3/8 spacer
2005 VW Jetta
PostPosted: Tue Jul 08, 2008 8:01 pm
I got good news, i found the spacer that i misplaced, and i also found out that its that same problem you guys were talking about in the first place, the "three loose screws", is there a way to get that Economizer Cover gasket for that 1920? If so please tell me where i can possible get that Economizer Cover Gasket is and point me in the right direction.. thanks
2005 VW Jetta
 Post subject: Holley 1920 gaskets
PostPosted: Wed Jul 09, 2008 7:34 am
You can buy just the gasket from a good carb shop. Our shop out here has about 4 different thickness gaskets so you can shim the power valve. If you don't have a shop handy, you can get one out of a carb kit. However, the gasket may be fairly thick. I am using a the thinest gasket they have available of the four.
PostPosted: Mon Oct 13, 2008 7:13 pm
Did you try humming a few bars? :P
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 6 guests
