It is currently Sat Jun 20, 2026 10:21 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Sun Jun 29, 2008 10:28 am
Car Model: 87 B150, 1970 Valiant 4-door
"Are you taking the air cond off for weight savings or just because it's toast?"
I'm removing the A/C for space saving and tidyness, really. I want all that crap out from under the hood. (The compressor and back brackets waste about a cubic foot of space on the manifold side.)
I think the radiator will be more efficient without the condenser blocking it's airflow. I also suspect that an idler pulley drags less on the belt than the A/C compressor does.
I finally got my pulleys and guards. I installed with 7/16" a grade 8 bolt and nuts, and a 1-1/2" x 1/2" spacer...all from the Lowes hardware isle. The stock Lowes spacer is almost perfect. It could stand a .10 shim, but it'll live for now. (next phase of mechanical work--timing cover, oil pump and pan gaskets--will require the belt's removal anyway. I'll make sure I have a shim in hand before I start that project.)
PostPosted: Sun Jun 29, 2008 2:07 pm
Ed,sweet that it's coming together for you,don't forget to put in a good timing chain/gear set as long as your going to change the gasket. :wink:
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
