It is currently Thu Jun 18, 2026 9:21 pm
 Post subject: Heat riser box
PostPosted: Sun Jun 29, 2008 4:42 pm
Hello,
While redoing the intake/exhaust studs, gaskets and so on, I have come to the conclusion that the heat riser box which installs beneath the manifolds, is not worthy of re-installation. ( That it didn't fall off is surprising )
Any thoughts on where one of these might be procured?
Thank-you
PostPosted: Sun Jun 29, 2008 4:45 pm
The heat riser valve is built into the exhaust manifold. Which part, exactly, are you referring to as a separate piece?
PostPosted: Sun Jun 29, 2008 5:24 pm
Hi
The piece I speak of is a metal shroud that bolts with two fasteners and then an aluminum hose attaches to this and provides heat up to the carb.
Its construction appears to be light sheetmetal
PostPosted: Sun Jun 29, 2008 5:27 pm
It helps on cold start ups, and is especially handy on very cold winter days. The aluminum hose hooks to it and is routed up to your snorkel inlet. I run mine religiously! :D
PostPosted: Sun Jun 29, 2008 5:50 pm
Ah, that's not part of the heat riser. It's the thermostatic air cleaner heat stove. They go by on eBay from time to time, though I don't see any at the moment. They're all the same from '70 (first year) through '87 (last year). Definitely worth having, as Ted says.
 Post subject: Lol...
PostPosted: Sun Jun 29, 2008 7:20 pm
I have a few laying around... if you need another one shoot me a PM...
PostPosted: Mon Jun 30, 2008 9:44 pm
Doesn't that piece have a bracket on it which is used for the kickdown linkage?
 Post subject: No...
PostPosted: Mon Jun 30, 2008 9:45 pm
The bracket is bolted to the manifold bolts, the heat stove bolts to it with a couple of shorty bolts...
PostPosted: Mon Jun 30, 2008 10:21 pm
I've also got a few.... if anyone else needs one.
~THOR~
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
