It is currently Tue Jun 16, 2026 2:31 am
PostPosted: Wed Jul 02, 2008 1:01 am
I know there have been posts about dropping pans or oil pumps but... what about mounts? I've dropped pan before in my car (71 duster), but I can't remember how much clearance was left on the mounts.
Also, is it safe to jack the engine up by the bellhousing? Trying to see if its possible to do it w/o a hoist. Not sure if the aluminum in the 904 is sturdy enough. Was always iffy about using wood under the pan since pickup is so close.
PostPosted: Wed Jul 02, 2008 4:33 am
Yes, no problem. Just leave one side connected at a time and jack up the BH or even the oilpan with a wide block of wood (I've done both).
You may have to pull the metal mount/bracket on the engine on one or both sides to slide it all out.
