It is currently Thu Nov 19, 2026 9:42 pm
 Post subject: New Leaf Springs
PostPosted: Tue Dec 24, 2002 4:35 pm
I was breezin' thru the JC Whitney catalog and ran across 63 thru 76 new leaf springs for 54.95 ea. Has anyone used these? I have major sag on my 63 Dart and definatly need replacements.
PostPosted: Tue Dec 24, 2002 5:32 pm
I have a set on my '66 and they seem to be doing OK. I did have to drill out the holes in the front hangers and get some 5/8" bolts though. They use the big eye and bushing on those springs. :shock:
PostPosted: Wed Dec 25, 2002 4:34 am
Thanks Dennis, I think I'll order a pair. I have a 50% off shipping coupon and seems I can't beat that price. My front end kit I'll buy from Just Suspension. I think their kit with poly bushings is the cheapest around and I can just pick-up my purchase there. 1 hr. round trip. You see Ladd,... I'm Scottish, very thrifty folks(so I'm told) always looking for a good bargain. Hey!.... Jackie Stewart has'nt drove in ages. He's only a car owner now. Does that mean I can steal his nick name "The Flying Scottsman"? heh heh! :D
A Very Merry Chistmas to you and yours and to everyone!
Drew&Gail Gavin 63GT
 Post subject: spring
PostPosted: Wed Dec 25, 2002 5:44 pm
Been running a set of 5 leaf J.C.Whitney springs for 3 years only problem,they raised the 64 Valiant to high in back. Go for the 4 leaf springs.
 Post subject: Leaf Springs
PostPosted: Thu Dec 26, 2002 6:31 am
Do you have a part # on the new Leaf springs? The 5 leaf springs? I need them for a 72 dart but I don't have a catalog. Sounds like a great deal.I couldn't find them listed on their web site.
Rick
PostPosted: Thu Dec 26, 2002 9:21 am
Hey Rick,
Standard duty is 96NN7570PF
Heavy duty is 96NN7569BF
I don't know if it's cool with the board moderators for me to put whitney part #'s on here. :roll: But I'll wing it.
Your shipping would be the same as mine 18.20. Why not be Scottish and get a catalog from a friend and use the 50%off shipping coupon! :wink:
PostPosted: Thu Dec 26, 2002 9:27 am
RJ, Thanks for your input. Thats what I don't want either, is to have the car too high in the rear. I'm going to try to get the car level as possible so I ordered the 4 leafs.
Thanks, 63GT
 Post subject: RE-e-New Leaf Springs
PostPosted: Fri May 02, 2003 7:47 pm
Greetings Gentlepersons,
I just installed the new leaf springs suggested above on my 63 Valiant. They work well and definately have improved ride and handling as well as reducing some of the clunking sounds eminating from various parts on the Valiant's anatomy. The current catalog does not list 63 as being included in the range of cars covered by these parts, but they work on mine. The installation was like described above, but the part numbers in the latest catalog are different. Also, JC Whitney had only one spring in stock and had to send the other one 4-5 weeks later. That didn't hurt me, but in you are in a hurry you might want to chaek their available stock. Later.
Carl Zeamer. an old guy, please be gentle.
 Post subject: Leaf springs revisited
PostPosted: Mon May 12, 2003 6:53 am
I have a set of leaf springs which I had two leaves added to each side. I'm trying to decide if these springs would be good for a drag car or not. They are stiffer than stock, obviously. Is that good or bad for drag racing? I've read about Super Stock springs and believe that they have one more leaf on one side than the other, but are SS springs looser or tighter than stock? What is the best set up for drag racing? It's a stock slant 6 car now and probably won't ever see anything faster than 15-16 second quarter miles.
Also, what would be the best set up for my street car that I want to handle well? I may take it to an autocross occasionally. Should I keep the springs with leaves added for the street car and do something else for the crag car, or what?
PostPosted: Mon May 12, 2003 8:00 am
The stiffer springs will be better for an autoX car, and you will probably want to use something with more flex for the drag car.
Personally, I have used the JCW HD 5 leafs on both my cars and the are plenty stiff - even a little too stiff for my '64 road race Dart (light car).
I got the '64 to hook up well down to about high 14s with 245/60-14 street tires (S rated) and those springs. I think I could have softened it up and gotten better traction.
 Post subject: Thanks!
PostPosted: Mon May 12, 2003 8:26 am
Thanks Lou,
That's about what I thought. I figure I won't have too many traction issues with such a slow car. I'm switching rear ends and was thinking I would just swap the springs with the rear to avoid breaking or stripping the 30 year old U bolts, but I would rather keep the thicker leaves for my Dart and save the money of buying any new springs. The somewhat worn original springs on the Duster should be okay for now. I look forward to seeing you at Bristol.
