It is currently Sun Nov 29, 2026 12:55 am
PostPosted: Sat Jul 05, 2008 1:11 pm
thats needs to hook up in order for them to work right cuz my tranny on my truck is not working and only reverse is working it kicks foward when i hit the gas lucklly i got anther transmission in the back of my truck
87 d150 2bbl carb 225
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
89 f450 diseal 4x4 dually 5sp
PostPosted: Sat Jul 05, 2008 1:14 pm
Nope. Chrysler uses a throttle pressure linkage rather than a vacuum modulator.
PostPosted: Sat Jul 05, 2008 1:17 pm
so im guesing the trannys blown
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
PostPosted: Sat Jul 05, 2008 1:50 pm
If the truck moves forward when the throttle is opened and the fluid is full (checked idling in neutral) then yes, you likely have internal problems.
PostPosted: Sat Jul 05, 2008 2:38 pm
it doesn't really move it jolts foward but doesnt really go any where :? the fluid is fine the plan looks like it has some dents coming from the inside :( the other tranny i have is from a marauder that had a slant 6 it seems shorter you think the swap is do able onto my d150 truck ?
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
PostPosted: Sat Jul 05, 2008 2:56 pm
it looks like the same transmission i think its a 727 aswell i took off the pan it seemed like there were no visable internal problems its pretty dry though and needs a new filter
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
