It is currently Fri Jan 30, 2026 9:46 pm
 Post subject: /6 in a '53 Ford
PostPosted: Fri Jul 04, 2008 10:38 pm
6 Pack Dart
For all to see, this is how to put a /6 in a '53 Ford. It does require several trial positionings of motor to see how it's going to fit best, and what needs to be done next.
first the firewall needs a dent to clear starter,
http://i77.photobucket.com/albums/j59/r ... 000099.jpg
and a small notch in the pan to clear the frame cross member. plus a motor mount,
http://i77.photobucket.com/albums/j59/r ... 000094.jpg
also a motor mount for the other side
http://i77.photobucket.com/albums/j59/r ... 000096.jpg
I used a Volare radiator (cut 1/16" off each side flange to fit the radiator support). Next was the Offenhauser 4 barrel with Carter carb,
http://i77.photobucket.com/albums/j59/r ... 000101.jpg
http://i77.photobucket.com/albums/j59/r ... 000102.jpg
Last but not least the construction of the equal length headers.
I also used the 904 transmission that is positioned to set on the original Ford crossmember with fabricated linkage to the Ford collum shift. the end result with a few other fairly simple things added give these results.
http://i77.photobucket.com/albums/j59/r ... 000091.jpg
http://i77.photobucket.com/albums/j59/r ... 000093.jpg
http://i77.photobucket.com/albums/j59/r ... 000092.jpg
PostPosted: Fri Jul 04, 2008 11:04 pm
crazy and alot of welding ford it is terrible but i guess thats alright since its a really old one.
i see you stick welded the motor mounts on those are some crazy looken headers
87 d150 2bbl carb 225
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
89 f450 diseal 4x4 dually 5sp
PostPosted: Sat Jul 05, 2008 8:20 am
That's a really slick installation — thanks for showing it!
PostPosted: Sun Jul 06, 2008 12:52 pm
Poser
Nicely done Fopar! And what a surprize when ya pop the hood! What power plant was in the Ford originally?
PostPosted: Sun Jul 06, 2008 1:32 pm
6 Pack Dart
it had a V-8 flathead but the block had a real bad score in one of the cylinders, and those flatheads were notorious for overheating.
The automatic transmissions were 3 speed, cast iron cases with air cooling.
PostPosted: Sun Jul 06, 2008 2:58 pm
Site Admin
And how many years have you been running the Slant Six in your Ford? :lol:
Turning 15.3's now? Slick! :D
CJ
PostPosted: Sun Jul 06, 2008 3:34 pm
6 Pack Dart
About 25 years, seems like yesterday when I finished.
PostPosted: Sun Jul 06, 2008 8:30 pm
Impressive to eyeball and more impressive to ride in! This car scoots. How bout a photo of the guage cluster, Richard?
Paul Olds
PostPosted: Sun Jul 06, 2008 9:01 pm
6 Pack Dart
Dash pictures
original dash
http://i77.photobucket.com/albums/j59/r ... sc_030.jpg
My revised dash
http://i77.photobucket.com/albums/j59/r ... ewDash.jpg
And dash was not cut to fit this cluster
