It is currently Tue Dec 30, 2025 6:59 pm
PostPosted: Fri Jul 11, 2008 12:20 pm
J. Spiva at polybushings.com is gearing up to make us good polyurethane spools for the '73+ slant-6 engine mounts, per [url]this thread[/url]. All of the '73-up passenger car slant-6 engines are said to take the Anchor #2376 low-quality rubber replacement spool, which is round in cross section. However, the NOS '80-'83 spool-and-bracket assembly we sent to Spiva contains an oval spool, not a round one. So, there are questions! Do they start out round (per the Anchor 2376) and are forced into an oval hole? Or are there two types of spool and an incorrect consolidation in Anchor's catalogue? The spool itself was never serviced as a separate part; Chrysler wanted you to buy the spool-and-bracket assembly.
Also, Spiva wants a good-condition through-bolt for this type of mount for dimensional accuracy in the repro. Anyone got one for offer?
PostPosted: Fri Jul 11, 2008 12:41 pm
I have some used, but original spool mounts in the garage along with the big bolt and I'm close enough to deliver to Mr. Spiva.
<edit>
OK, Mr Spiva is farther away than I thought, but still fairly close. I can box up and ship the parts and have them there in a day or two.
PostPosted: Fri Jul 11, 2008 12:48 pm
I know for sure that the transmission mount is oval. I thought the inserts were interchangeable with the motor mounts, but I am not positive. :?
PostPosted: Fri Jul 11, 2008 1:04 pm
Slantzilla: No, the trans spool is not the same as the engine spools, and the slant-6 engine spools are not the same as the V8 engine spools.
J225: Thanks! What's your take on the round vs. oval question? If the spool itself is all the same (and always oval), then he already has that part and just needs the bolt. If there are round vs. oval spools, then (A) he needs a good round one to model from, and (B) Anchor are telling lies when they say the round #2376 will fit all.
PostPosted: Fri Jul 11, 2008 1:19 pm
Dan,
I'll look at the parts when I'm home from work in a few hours and report my findings. As it stands I've never examined the mounts' shape closely at all. Watch here for photos!
 Post subject: They are oval!
PostPosted: Fri Jul 11, 2008 5:12 pm
The 1973 mounts I have use oval insulator bushings. I think sending this early factory example along with the bolt can only help our cause.
PostPosted: Fri Jul 11, 2008 6:55 pm
OK, well, your '73 is the first usage of that spool, and the '80-'83 part we sent him is the last usage, so I think it's safe to say they're all oval. Maybe I was just looking at the Anchor photo wrong, or they used a generic photo, or whatever. Anyhow, yeah, more sample parts are definitely better than fewer. Thanks!
PostPosted: Fri Jul 11, 2008 9:37 pm
why do you want poly engine mounts? unless it's a race car...
zedpapa
1970 dodge dart w/225 /6 bored .040" over, holley 390cfm w/vac. sec., compcams 252s, clifford shorty headers w/2.5" exhaust w/flowmaster, f-body 11" front discs, aluminum A-833OD, 8 1/4 w/3.21 SG
soon to have 5 gears!!!
PostPosted: Fri Jul 11, 2008 10:13 pm
Looks oval to me.
 Post subject: Using old rubber...
PostPosted: Fri Jul 11, 2008 10:15 pm
It's better than sinking the $$$ into a set of chinese rubber mounts that aren't that great... at least they will be oil resistant, unlike the OEM rubber ones that seem to suck itup and slowly disintegrate...
Just as an FYI, I have a new set of anchor mounts on the Hpak duster... and the carb stud has already left a dimple in the hood after a couple of aggressive launches....
PostPosted: Sat Jul 12, 2008 6:06 am
should be getting my tranny spool mount from www.magnumhp.com soon.
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
