It is currently Wed Oct 14, 2026 7:33 am
 Post subject: Holley 350 cfm
PostPosted: Mon Jul 14, 2008 9:57 pm
Do these carbs work very well on the slant? What kind of power and mileage would you be looking at with it?
Ronnie
http://www.cardomain.com/ride/2714941
 Post subject: Yes and No...
PostPosted: Tue Jul 15, 2008 5:34 am
They can work well on a slant. But... you have to spend the $$$ to get the parts to tune it to your particular build. On top of that you will need a 2 barrel intake minimum and an adaptor.
Power within certain rpm limits would be better than the bbd, mileage can be similar or poorer (are you a lead foot?), depends on how you tune it and how you drive, also.
PostPosted: Tue Jul 15, 2008 7:59 am
This setup is very popular in Argentina. I use 54 main jets and 85 power valve and works very good.
Millage is around 14-16 mpg on a 3500 pound car with A904 in city driving. On the road its around 18-20. But this depends a lot on the foot of the driver... holleys go fast if you want.. but they feed a lot!
Here´s a video reving... there it had a small lean acceletation pump problem witch I resolved yesterday... now its faster...
http://www.youtube.com/watch?v=pNWRmaa72_M
Dawm.. I want to take this car to the streets and film some action!
If you need any help just ask!
Martin
PostPosted: Tue Jul 15, 2008 8:04 am
That car sounded real good. If I need any help Ill be sure to contact you. :)
Ronnie
PostPosted: Tue Jul 15, 2008 5:18 pm
On this carb where does the hose from the distributor connect?
Ronnie
 Post subject: Holley 2-4 barrel 101...
PostPosted: Tue Jul 15, 2008 6:39 pm
These are sooo simple in that respect it's not even funny...
You should only have 3 hookups for vacc. on the carb...
3/8" tube at the base- PCV
1/8" tube under the fuel bowl at the base - vacc. tap for vacc. gauge
1/8" tube sticking out the left side of the metering block when looking at the fuel bowl... timed vacc. distributor port
That is fine unless you get one of the 'Ford' only designs, in which case
you have to rework the throttle lever a bit, and the PCV hook up is deleted from the carb base plate...
These carbs can be found regularly at swap meets in fairly rebuildable condition for $50-75 tops. (Rebuild kit for $30, and another $30+ in jets and misc. carb parts during the tuning phase...)
PostPosted: Tue Jul 15, 2008 6:54 pm
I already have one. Got one used but never ran for 150.
Ronnie
PostPosted: Tue Jul 15, 2008 7:00 pm
I use the one in the block.. but it redrill the hole in the butterflys body so that vaccum is present at engine idle.
Now i don´t use it anymore.. i setted timing to 18º idle ande 34º at 4000 rpm. I do use the same vaccum port for vaccum meter in orden to choose a correct power valve.
PostPosted: Tue Jul 15, 2008 7:04 pm
I just took a look at it and I dont have any hookups on the carb.
Ronnie
PostPosted: Tue Jul 15, 2008 8:48 pm
The one in the block must be there.
PostPosted: Tue Jul 15, 2008 9:24 pm
There are a couple of possibilities here...
like in the previous pic, the threaded tap may not be installed if it's that type of block...
You have a 'race' only metering block not drilled for the tap (vacc. advance on a circle track car is just not necessary)
they swapped the block with something else and tryed to make it work, it didn't so they dumped the carb...
The best way to tell if it's still OEM, is to check the numbers stamped into the airhorn on the right side above the metering block... in a similar location on the top of the metering block there will be a set of 4 digits, that should correspond with the one's on the airhorn... if not... somebody did a swap out...
PostPosted: Sun Jul 20, 2008 8:05 pm
I am new to carbs so bare with me. the block is on the side of the fuel bowl?
Ronnie
 Post subject: Kind of...
PostPosted: Sun Jul 20, 2008 8:10 pm
The metering block is sandwiched between the fuelbowl and the actual caburator body itself....
Before you get too far into this, you need to get a book on Holley's...
It will give you the break down on the carb, carb numbers, parts numbering system, kits, jetting, theory....It'll be the best $20 spent...
PostPosted: Sun Jul 20, 2008 8:18 pm
thanks for the tip. ill be sure to get one to get one so i can learn more.
Ronnie
PostPosted: Mon Jul 21, 2008 8:52 am
I just picked up a NEW Holley 2210 series at Carlisile. I was OEM on a 360. It wont work for what I wanted it for. I just want to get the $50 I paid for it anyone is interested.
Scott
Scott
1956 Dodge Custom Royal Lancer
1980 Road Runner (Dont call it a Volare!)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette Stingray
Users browsing this forum: Bing [Bot] and 9 guests
