It is currently Tue Jul 07, 2026 1:56 pm
PostPosted: Thu Jul 17, 2008 7:26 pm
How much NOS juice can KB hyper pistons take? It would be a plate NOS system. The motor was already done with hyper not fordged. Thanks.
PostPosted: Fri Jul 18, 2008 6:54 am
IF and I mean IF you have the top ring gap set for nitrous use you can spray 150 all day long IF your tune-up is good.
I have killed pistons both times I went over 150.
Contrary to the popular belief, a hyper piston will not shatter like glass. However, you can break one in half.
If you go over 150 you are bound to kill a head gasket anyway.
PostPosted: Sun Jul 20, 2008 10:01 am
That's cool. I was think a 100 shot might work. Thanks.
PostPosted: Tue Jul 22, 2008 5:22 am
I have KB hyperutectic pistons in a big block Ford that I have shot with a 125HP NOS plate system with a Jacobs "Mastermind" controller many dozens of times with no problems (except broken axles).
Pay heed to Slantzilla's comment on ring gap. Lots of NOS requires a looser gap than the normal .004/inch bore.
'63 Valiant V200 Convertible
225 Aluminum Block
PostPosted: Tue Jul 22, 2008 6:28 pm
Thanks for the help. I will have to let you know how it works out, when I get sometime to work on it again.
PostPosted: Fri Jul 25, 2008 9:40 pm
On my hyper pistons I have run the top ring gap as for aout as .035". IIRC, KB recommends .024".
Keep your tune-up good and you can spray 100 shot forever. Bad tune-up will kill something faster than you can believe. :shock:
Be aware, the hit of nitrous is very intoxicating. 100 won't be enough for long. :twisted:
