It is currently Thu Nov 12, 2026 10:59 pm
 Post subject: What is wrong?
PostPosted: Wed Jul 16, 2008 1:58 pm
The battery on my 65 Dart GT is not staying charged. When I start the car, usually by jump starting it, the amp meter shows a slight charge. This makes me think it's charging. However, when I honk the horn, the gauge moves more toward "C" . I know the horn draws a lot of current, so why is this happening?
PostPosted: Wed Jul 16, 2008 2:09 pm
I would try another battery first , if you have one around ,that one may have bit the dust.
Dave
81 Dodge D150
It looked easier in the book .
PostPosted: Wed Jul 16, 2008 2:40 pm
Thanks for the quick reply, Dave. It is a newer battery, and was checked at O'reillys. They said it was good.
PostPosted: Wed Jul 16, 2008 2:51 pm
Now it's time to check the charging voltage.
Connect a voltmeter and see what you get. You should read 13.5 volts or better across the battery terminals with the engine running at highway rpms.
-Mac
PostPosted: Thu Jul 17, 2008 6:53 am
O.K.,
I read 14.8V across battery.
PostPosted: Thu Jul 17, 2008 8:00 am
14.8v is excessive and will make problems; your voltage regulation is not what it should be. You will likely want a replacement voltage regulator, and you'll want to run a ground loop (alternator housing to regulator base to battery negative terminal).
But despite the excessive charging voltage, your tests so far say the battery's OK and the charging system isn't failing. Your problem with the battery not staying charged, then, is probably because something is drawing current and running the battery down after you've switched off the ignition. Test this by disconnecting the battery negative terminal and leaving the car overnight or however long it usually takes for the battery to run down. Then go back to the car, reconnect the cable, and see if it starts. If so, you'll need to chase down the circuit that's drawing the current.
PostPosted: Thu Jul 17, 2008 9:08 am
Thanks SSD,
I took off the regultor,which was a new looking solid state one, and installed an old used, mechanical regulator. Now it reads 14.4V. I will get a new regulator, put on the noted grounding wires and check it again. It still shows an increased charge when I honk the horn.
PostPosted: Thu Jul 17, 2008 12:02 pm
Don't overlook the possibility of a current drain running the battery down while the car's off. You can test for that with a multimeter or a test light in series with the battery and the car off.
PostPosted: Thu Jul 17, 2008 12:41 pm
Yes,
I disconnected the ground cable, and measured from battery to cable and had 0.25V draw with everything turned off. VR1001 will be in tommorrow.
 Post subject: Re: What is wrong?
PostPosted: Fri Jul 18, 2008 12:06 am
Yes,
Just checking if you meant 0.25 Amps? As if I'm not mistaken you should measure current flow between the battery and cable. Maybe a typo on your part or possibly your meter is on the wrong setting?
cheers
AP6
PostPosted: Fri Jul 18, 2008 4:01 am
does your car have a light in the boot because it might be staying on and draining your battery i had that problem and it took a while to find that problem hope it helps..
slants6 forever
PostPosted: Fri Jul 18, 2008 4:29 pm
I installed the $47.69 VR1001, ran ground wire per SSD, and now have 13.6V at the battery when running. digger12, I did have my meter set on Volts when I checked from the battery to ground cable. orgvgregal, no light in the boot. Jump started it and drove about 5 miles. Will try to start tommorrow. But why does it show an increase in charge when I honk the horn?
PostPosted: Fri Jul 18, 2008 5:39 pm
I think it should increase when you honk the horn because its drawing power i just went and checked mine and it did the same i think its normal
slants6 forever
PostPosted: Fri Jul 18, 2008 5:44 pm
Try checking the Amps (current) with the car turned off and connected as above. Sorry about the bad drawing...
You should be able to check if something is draining the battery while its sitting.
Another question..After you jump start it and have it running for a while - 10-15 min. Is it able to restart easily? If so its possibly charging ok. Then you need to figure out why its draining when sitting.
Your Ammeter has got me puzzled though, and I dont have my car yet to be able to have a look, But I would have thought that if you jump started the car and your battery was low on charge, the ammeter would be nearly showing full scale as its starting to recharge the battery?
Maybe it doesnt work that way? But I'm sure some other people could say!
AP6
PostPosted: Fri Jul 18, 2008 5:57 pm
Digger12 your right if the battery was flat the ampmeter would show full scale charging .
slants6 forever
