It is currently Tue May 26, 2026 3:35 am
Post new topic  Reply to topic  [ 75 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Thu Jul 17, 2008 8:48 pm
Are there any left from pep boys? If so can someone that has a Pep Boys around them grab one for me? I can Pay Pal the money asap.
http://s88.photobucket.com/albums/k199/ ... 2%20scamp/
www.forabodiesonly.com
PostPosted: Thu Jul 17, 2008 9:19 pm
Call the Puyallup, WA Pep Boys, tell them your name is Josh and see if the pump is still there. I wasn't able to go get it.
PostPosted: Fri Jul 18, 2008 6:31 am
The stamped steel cover is pretty thick material, .125 (1/8th thick) if I remember right.
The flat cover was also on some of the early factory pumps, until the factory engineers discovered that it is possible for a small amount of water to collect at the lowest point in the pump, that place is in the pump's impeller cavity, against the flat cover's inner surface.
If that water freezes, the impeller jams and breaks the pump's drive gears.
The cast cover with the "bumps" allow for a small amount of water to settle outside the impeller cavity. The bump openings also helps the oil flow into and out of the impeller cavity a bit better.
Very Interesting. This prompted me to go back and look more closely at what I got. I ordered 2 units for engines I am building in the near future, and a couple of spares.........uh, just because everyone knows how often the pumps go bad :lol: **dripping sarcasm** :wink:
Anyhow
Everything in a "Clevite" box is marked made in USA, and has the flat stamped steel cover
1 unit was in a "Sealed Power" box, no markings on where it was made, and has the cast cover with the humps in it.
Also 1 unit was in a generic white box, no "made in" markings, Just a P66-C sticker on it. Again with the cast, humped cover.
From what Doc says, guess I'll be using the cast covers first!
CE
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
-67 Dart /6 4bbl, Leaning Tower of Power!!!
PostPosted: Fri Jul 18, 2008 9:38 am
turns out one of the oil passages is larger in the pump with the cast cover. Check it out.
and obviously some other casting differences.
CE
PostPosted: Fri Jul 18, 2008 3:17 pm
Anyone know if any other parts stores are having the same clearance on the M66C pump? Partsamerica.com has thm listed for $109.99. It seems that the price jumped up about 20 bucks since the last time I checked on slant oil pumps (about 2 weeks ago).
 Post subject: More on Oil Pumps...
PostPosted: Fri Jul 18, 2008 8:25 pm
Wow... all I can say is: "Thanks Charrlie... I owe you a dinner"...
I just received my order of pumps... what a killer deal!
Picked-up 3 big boxes of oil pumps from my local Pep Boys... I was shocked to see that the warehouse used UPS to ship over 100 lbs of oil pumps, in 3 seperate boxes, to my local store. The shipping had to have cost more then what I paid for the pumps. ($2.40 each) :shock: :?
Looking at the boxes, some of these pumps have been sitting around for a long time. This is a good example of all the "re-boxing" that gets done in the parts business these days, the pumps in my order came in Seal Power, Melling and Dynagear boxes and the pumps are both Melling and Dynagear produced.
As an FYI, there is a lot of info. about the SL6 oil pump in this article:
http://www.slantsix.org/articles/oil-pu ... report.htm
I need some time to "pick through" my lot, I will do that over the next week or so... as I pull the drive gear off each pump.
So here is the plan... Keep an eye out for a post about doing a "group buy" oil pump drive gear heat treating run.
If you purchased some of these Pep Boys "fire sale" pumps or if you have some other pumps around, pull off the drive gears. I will talk to my local heat treater about case hardening another lot of oil pump drive gears in the near future.
If someone wants to help me by acting as the 'distributor', to collect and then re-distribute (mail) all the case hardened gears... I will make it worth their time.
Drop me a PM.
PostPosted: Fri Jul 18, 2008 8:39 pm
What's the best way to pull off the drive gear?
To anyone who 'may have bought 1 too many....' :wink:
You guys sure did get a bargain. If anyone would be interested in selling one and sending to Sydney. Please PM me to work something out. Thanks. :wink:
AP6
PostPosted: Fri Jul 18, 2008 9:00 pm
Use an oil pump drive gear puller... :wink: :roll:
For pumps without a gear keyway and key, you can remove the cover and then "hammer" the impeller shaft through / out of the gear and pump body.
Pumps with a keyed gear, need the special puller.
PostPosted: Fri Jul 18, 2008 9:04 pm
Digger, these pumps won't work on your RHD Australian Valiant. The RHD cars use a different pump, without a filter mounting pad (has female inlet and outlet threads for pipeworks to and from the remote-mounted filter), so there's room for the steering box. Our LHD pumps have a filter mounting pad integrally cast into the pump body and the filter screws right onto it.
PostPosted: Fri Jul 18, 2008 10:30 pm
ah ok..then scratch that idea.. :cry: Thanks. would have been annoying to have got one then realized 'something is not quite right!'
AP6
PostPosted: Sun Jul 20, 2008 11:14 am
Hey , when doing the pump gears, how bout the dizzy gears too ?
-Mike
PostPosted: Sun Jul 20, 2008 11:32 am
It's, um, kinda hard to case-harden the nylon distributor pinions. They tend to melt rather than harden. :lol:
PostPosted: Sun Jul 20, 2008 11:34 am
yeah, doc can you put me down for one heat-treated plastic distributor gear too please. im tired of replacing the worn-out bronze ones~
PostPosted: Sun Jul 20, 2008 1:14 pm
Anyone else need a pump?
