It is currently Thu Dec 25, 2025 9:46 pm
PostPosted: Thu Jul 10, 2008 2:59 pm
i have a set of fury wagon disc brakes off a 73-75 era and was wondering if theyd work on my 73 dart swinger. can someone help
thanks
PostPosted: Thu Jul 10, 2008 4:07 pm
Not if it's a C-body. B-body stuff will bolt on, but C-bodies are different. The later '75 and newer small Fury is a B-body, but the older ones are C-bodies. The C-body year break is '73 if memory serves so if you have the 1973 only disc brakes you can sell them for decent money to a C-body fan that want to upgrade.
PostPosted: Thu Jul 10, 2008 5:55 pm
thanks for the help
PostPosted: Tue Jul 15, 2008 1:22 pm
thanks
Would you be interested in selling your C-body brakes?
It is easier to REACT,
than it is to THINK!
Middy.
PostPosted: Tue Jul 22, 2008 1:09 pm
I used c-body rotors and caliper brackets on my a-body disc brake spindles it works great. This way you can utilize the larger rotors of the big cars. I believe you could have either slider type calipers or the style that slide on pins like in early E-bodies which is what I chose. Mopar Action did a story on this with pictures of the parts for identification. Check out their website it is in the tech archives.
70 Valiant 225,super six
65 Dart More Door race car 225/4bbl 8 3/4 3:91
70 Dodge D100 Sweptline short box 225/4spd
PostPosted: Tue Jul 22, 2008 10:27 pm
The only way to use C body rotors on A body spindles is if you had a set of custom wheel bearings made.
PostPosted: Tue Jul 22, 2008 10:51 pm
Andy is right. The car your parts came from was not a C-body. Plenty of B-bodies were given names formerly used on C-bodies.
PostPosted: Wed Jul 23, 2008 7:40 am
I have thought about having a custom wheel bearing made for this application since it would allow a C to A swap. It is a simple change to the bearing, basically it just needs a slightly different OD. With the conversion bearing a person would be able to slide the 11.75 x 1.250 C body rotor onto any A,B or E body knuckle.
The main reason I'd do that is that then my Viper kit would be a better bolt on kit and the pad spacers could be elminated. The Viper caliper is designed for a 1.250 rotor rather than the 1.00 thick rotor that came on the big B body cars.
PostPosted: Wed Jul 23, 2008 1:02 pm
You are correct, I got the parts from a B-body with a C-body name, sorry about that. Here is the M.A. link I was talking about.
PostPosted: Wed Jul 23, 2008 1:03 pm
http://www.moparaction.com/Tech/archive/disc-main.html
PostPosted: Wed Jul 23, 2008 1:59 pm
A body B, C, what body is the '72 Charger? And will any parts off of one fit a '74 Dart? I have one that is beyond repair and my Dart is willing to accept any upgraded part swap.
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
PostPosted: Wed Jul 23, 2008 3:30 pm
Chargers are B-bodies. Those spindles and rotors are different than the '73 and later ones. Probably best to sell those to someone that wants older B-body disc brakes and find the correct stuff for the Dart.
PostPosted: Wed Jul 23, 2008 6:46 pm
'72 Charger stuff will bolt onto an A body (need big ubj) but the rotors are expensive if you can even find them. Most people use the '73 or newer stuff because it is dirt cheap.
