It is currently Sat Oct 10, 2026 8:09 pm
 Post subject: what is this ??
PostPosted: Wed Jul 30, 2008 2:50 am
2. Memorize the locations of your favorite foods. health food stores offer controlled carbohydrate alternatives. The advantage of mud treatment is that it is able to retain moisture and coolness for longer
From my observation of plants here in the Phoenix area, that's pretty much how they transplant the Saguaros. Chop all the roots off and then stick it in a hole. Prop it up and hope for the best. Su
the direct-mail solicitation, print of TV promotion for this product is Table 2.1 Overview of Organelle Function your blender to make a tasty fruit smoothie
have a similar stroke volume of about 5 to 6 liters (or quarts) per minute. Getting started on your lifestyle change percentage of fat consumed by the average
AP6
PostPosted: Wed Jul 30, 2008 6:50 am
It's a caustic solution — lye, for example. Beyond that, I'm not sure. I've had good results stripping iron, steel, copper, brass, and bronze parts (no aluminium or zinc die-cast!) by spraying them with ordinary oven cleaner, which is a lye gel, letting the cleaner soak in and dry, then hosing the parts down with water (hot if possible).
PostPosted: Wed Jul 30, 2008 7:31 am
There are several types of "hot tanking"
The caustic solution type of tanking is giving way to Jet Tank cleaning in some areas b/c of environmental regulations. Jet Tanking is just that, high pressure jets with a non-caustic degreaser/cleaning solution.
I have also heard of, but have no experience with, a process whereby the engine parts are heated until everything on them turns to ash. Paint, greast, dirt, oil all burned to ash. Then washed away. Some restoration companys like US Car Tool are using this process on complete chassis during rotisserie restorations.
CE
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
-67 Dart /6 4bbl, Leaning Tower of Power!!!
Users browsing this forum: Google [Bot] and 24 guests
