It is currently Tue May 19, 2026 7:27 am
 Post subject: early a-body radiators
PostPosted: Wed Jul 30, 2008 1:33 pm
Car Model: 1964 Valiant V200
This is a question within a rant so bear with me. Every early A-body I've had with the big-tank radiator starts leaking from the top tank. They always start cracking near the cap.
Anyway, to cure this problem 15 years ago, we bought a NOS radiator for my grandma's (now my) Valiant. Now the NOS one is cracked in the same spot. I tried soldering it up but it leaks again..
So I have the original radiator (blown apart tank seam) and the formerly-NOS radiator with a crack...
On our old Dart I was able to get a local shop to solder up the cracks but it cracked again...
Is there a solution? I'm planning on just bringing both radiators down to the radiator shop that did our Dart's rad and having them build one up from the best parts of both but I do feel like I'm going down the same path.
Of course I could just accept this state of affairs and solder cracks every couple of years...
PostPosted: Wed Jul 30, 2008 1:57 pm
I've used de-soldering braid to fix cracked tubes (make the braid wide and wrap around, solder) Sort of a metal composite.
I think the same principle would work. :idea:
PostPosted: Wed Jul 30, 2008 1:58 pm
See this thread.
PostPosted: Wed Jul 30, 2008 2:03 pm
So Dan,
Is your source set up to build more of these radiators?
PostPosted: Wed Jul 30, 2008 2:15 pm
Nice but I'd like to have more of a stock look - I used a universal aluminum radiator from Summit in my V8 64 Dart. It worked so well I had to go back to a hotter thermostat even in LA traffic!
PostPosted: Wed Jul 30, 2008 2:22 pm
I was trying to relocate a stock A/C radiator recently too. All you can really do is keep looking and post up in the want-ads.
If you want to get yours rebuilt/repaired, call around to radiator shops in your area. Try and do research of possible to locate an 'old guy' that has been doing this for a while.
I personally like the look of original radiators myself, and I had to search for quite a while to find one. They are getting rare.....
PostPosted: Wed Jul 30, 2008 2:39 pm
I have a guy (actually the son of a guy) that's been in business since 1947. They did the radiator on my dart.
PostPosted: Wed Jul 30, 2008 3:01 pm
Good question! I think so — give him a shout and ask. Remind him of the '62 Dodge Lancer he built for Dan Stern and see what he says.
PostPosted: Wed Jul 30, 2008 3:09 pm
The roundtop tanks have always been relatively difficult to solder to the core with good leak-free durability, and as I understand it they got a lot harder when the cores started coming through with the tank interface edges set up without the double flange (as the original round-top cores had).
PostPosted: Thu Jul 31, 2008 8:31 am
I stuffed an F-body radiator in mine - it's almost a direct fit. However, the junkyard radiator had, you guessed it, cracking problems too. I'm now in the process of putting in an aluminum circle track unit.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
