It is currently Wed May 27, 2026 5:00 am
PostPosted: Wed Jan 01, 2003 11:08 pm
My left rear wheel cylinder is leaking fluid and needs to be replaced. Can the wheel cylinder be replaced without having to take off the brake shoe? In the manual that I have it talks about different special tools that are used to remove the brake shoe. Do you really need these special tools?
PostPosted: Sat Jan 04, 2003 10:33 pm
Kinda yes, kinda no. You definitely have to remove the uppoer springs and spring/pivot pin in the middle of each shoe. you can then leave them hanging there and will have anough room at the top to remove the cylinder.
 Post subject: Special tools?
PostPosted: Mon Jan 06, 2003 4:58 pm
What special tools? :D I've replaced brake shoes and cylinders using just a needle nose pliers, a regular pliers, and a socket wrench.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Wed Feb 05, 2003 5:02 pm
No special tools required...granted, it may be easier with the proper tools but you can remove the shoes with simple hand tools from around the house.
-Don
Forget the flowmasters...here come the good ol' GLASSPACKS!!!
PostPosted: Thu Feb 06, 2003 4:28 am
You can purchase the proper brake pliers for around $10 and another 3 or 4 for the cup tool. For the number of times you will do brake jobs paying for a Snap-On set is just not warranted.
The pliers especailly make the job so much easier I would consider it a mandatory tool in your box.
Dave Clement
68 Barracuda (Hot-Rod \6)
http://mysite.verizon.net/vze4pgxf/
