It is currently Tue Nov 10, 2026 9:17 am
PostPosted: Sat Aug 09, 2008 4:44 pm
can i paint the alternator? and if so some advice on how to dis-assable it would be awesome? thanks!
PostPosted: Sat Aug 09, 2008 5:12 pm
You can, but it'll look bizarre and make it run hotter. The rear housing half can be removed just by undoing the three through bolts, but to remove the front housing half you have to have a pulley puller (special tool) and a press to reinstall the pulley. Better to mask off and just paint the visible part of the stator (between the two housing halves) and maybe the pulley.
PostPosted: Sat Aug 09, 2008 7:45 pm
thanks for the awesome info slantsixdan! i think i'll take your advice about it getting hoter and just mask the whole thing off and only paint the pully.
cheers!
PostPosted: Sat Aug 09, 2008 9:20 pm
When I had my alternator apart to change the bearings, I painted the center section from it's previous rust.........
But that's all I'd paint.
