It is currently Wed Nov 11, 2026 1:17 am
 Post subject: How much for...?
PostPosted: Sun Aug 10, 2008 1:10 pm
How much can I expect to pay for a 5 terminal, "Orange Box" module?
Just tuned up my '79 van, and noticed the box is starting to "bleed". I just installed a Blaster 2 coil, 8mm plug wires, NGK UR4 plugs, Bluestrak cap, and the good Napa rotor. I can feel a little better performance and idle quality, but I want to make sure the box is'nt crapping out on me.
Also, I have 5 wires going to the ballast resistor, (4 terminal). Is it possible to (easily) convert this to single ballast? I'd like to install the one I got with my new coil, but it is only a single, 2 terminal resistor.
Thanks for all the help you all have given me!
:wink:
"MOPAR or NOCAR!"
PostPosted: Sun Aug 10, 2008 7:23 pm
I don't know about the module, but I just installed a pertronix flame thrower coil, and I had to by pass the ballast resistor. I don't know if you have to or not, but you can Read This
'74 Duster 225 Super Six w/904
14" Cragar SS wheels
PostPosted: Mon Aug 11, 2008 9:13 am
The Mopar orange box is inexpensive (~$42 @ Jegs), but I believe they're all foriegn made now; mine lasted about 2K mi. The Mopar chrome boxes (~$66 @ Jegs) I looked at were also foriegn made and looked rather sloppily put together (heatsink on a little crooked), so I bought a top-of-the-line NAPA (~$65) and have had no problems with it since.
PostPosted: Mon Aug 11, 2008 11:32 am
Gah! No orange boxes! Boxes of oranges yes, but no orange ignition boxes. Go buy Standard Motor Products LX101. $43.79 at rockauto.com. This is a high quality ignition box unlike the orange boxes produced for at least the past 5 years. 4-pin modules superseded the 5-pin modules years ago.
PostPosted: Mon Aug 11, 2008 4:44 pm
I found a Napa Echlin box for 29.00 today, anyone have good or bad opinions about these? The box on it now works, but is starting to bleed gooey crap.
"MOPAR or NOCAR!"
PostPosted: Mon Aug 11, 2008 8:17 pm
The origional voltage regulator on my car oozed gooey crap before I got it. It was replaced with one that almost fried my batt. :shock:
I have no idea what makes them do this.
I doubt these are related, but just putting in my info.
PostPosted: Mon Aug 11, 2008 10:17 pm
Sounds like the box is overheating or is of poor quality. Can you measure the voltage between the coil + terminal and ground with the engine running? Is the coil stock?
PostPosted: Tue Aug 12, 2008 12:50 pm
NAPA sells both a cheaper and a more expensive box when last I looked. I hope the more expensive to be more reliable; in the past I've been *told* that the top-of-the-line boxes carried a lifetime warranty and exchanged a dead (Ford) one under it, but since then (different) NAPA guys claimed it has no warranty.
If the potting is melting, something inside the box is overheating and the box is destined to fail.
PostPosted: Wed Dec 03, 2008 10:00 am
where can I get a wiring harness to convert my points ignition to electronic?
I have the electronic distributor, and the 4-pin lx101 is on it's way. Will the 5-pin harness plug into it? I can order one from Jegs.
