It is currently Thu Jun 18, 2026 9:49 am
 Post subject: Engine mounts?
PostPosted: Sun Jan 12, 2003 10:23 pm
While I was working on the Dart today, I noticed that the engine mounts are completely FUBAR.
Where can I get polyurethane engine mounts and a poly tranny mount for a 225 w/ an A904? And how can I support the engine while I'm changing the mounts? I see no way to hold the thing up :?
PostPosted: Mon Jan 13, 2003 7:41 am
I don't know where to get poly mounts, but rubber mounts can be found easily in autoparts stores. Are your mounts the biscuit type or the later spool type?
When I changed my mounts (biscuit type) over the summer, I supported the motor under the oil pan with a very large block of wood and a floor jack. I simply unbolted the old mounts, jacked the engine up, slid the new mounts in and let it down.
'68 Dodge Dart 4dr Sedan
PostPosted: Mon Jan 20, 2003 4:09 pm
They're biscuit, I think. It's a 1970.
PostPosted: Mon Jan 20, 2003 6:11 pm
I use the same block of wood on the oil pan method. (Never changed the mounts, but i had to pull the passenger side mount to remove my oil pump) Just have a helper to tell you when to stop jacking.
-Aaron
PostPosted: Mon Jan 20, 2003 6:15 pm
Hey,
I've done the same trick with the block of wood and jack under the oil pan only i've used it to take the transmission out...
Justin
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 7 guests
