It is currently Sat Jun 13, 2026 8:09 pm
 Post subject: Specialty Tools
PostPosted: Mon Aug 18, 2008 3:13 pm
Site Admin
I want to buy or make a jig for drilling out manifold studs while the head is mounted to the engine.
Any leads, or thoughts on design?
CJ
PostPosted: Mon Aug 18, 2008 4:37 pm
I would make a plate that looks like the manifold gasket except that it shouldn't have port openings. The stud holes should be drilled oversize to accept a hardened drill bushing. I think it should be at least 1/2" thick.
PostPosted: Tue Aug 19, 2008 3:22 am
PostPosted: Tue Aug 19, 2008 8:52 am
Site Admin
I've got a couple exhaust manifolds so will make a tracing of them and see where they average out.
I was looking for drill bushings for an "F" and was having a time of it finding someplace I could buy just one F, and a bunch of 5/16" bushings. They seem to come in sets of varying sizes.
They would have to be removable types so the "F" bushing could be placed in the needed location. Right now all I have is 1/4 flat stock in an appropriate length. I'll stop off at the steel company here locally and get some 1/2" or thicker flat stock and build it. They may have the drill bushings or availability also.
Do you have a drawing of the stud and port locations? I can compare that to what I find on the manifolds and see how things line up.
Thanks!
CJ
PostPosted: Tue Aug 19, 2008 4:47 pm
PostPosted: Tue Aug 19, 2008 7:04 pm
Site Admin
The second link worked, the first didn't.
Well, yep. The F drill bushing would work.
Yep. Studs for the manifold to head. Silly me. :roll:
I'll just use a gasket to measure things up. I'll eventually get this figured out.
I can double check dimensions on my spare head. Thanks!
CJ
PostPosted: Wed Aug 20, 2008 1:00 am
Users browsing this forum: Ahrefs [Bot] and 3 guests
