It is currently Tue Dec 23, 2025 12:46 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Mon Aug 25, 2008 4:32 pm
Platinum plugs are generally not money well spent on a slant-6 engine. Instead, take advantage of the fact that you have a pre-1975 engine and use the NGK #ZFR5N extended-nose spark plugs. Remember to remove the metal ring washer from each plug before installing it.
I have seen this suggestion to remove the metal ring washer from the sparkplugs in other posts. Can someone explain what this procedure does.
PostPosted: Mon Aug 25, 2008 6:39 pm
See here.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 5 guests
