It is currently Wed May 27, 2026 12:22 am
PostPosted: Tue Aug 26, 2008 12:24 am
Hello guys,
As said in the title : I'm having a hell of a time to mate these two together...
I now know I certainly have a stripped thread in one of the T/C holes (due to my idiot self trying to screw when the screw wasn't straight...) but the other 3 are fine and I can't seem to screw more than one of them...
I know one of the holes is offset (in terms of angle right?) but I tried every possible combination and each time only one of the bolts will bolt...
I'm using a 67 trans with a 72-73 (not sure) engine. Is that a concern?
And also : when I received the engine, the flexplate was bent on one ear so I had to bend it back but it's probably not really flat anymore.
Pleaaaaaaaaaase heeeeeeeelp me!!! :cry: :cry:
I thought I was seeing the light but then again another problem!!!
I'm getting sick of it... oh well, that's life!
Marc
PostPosted: Tue Aug 26, 2008 12:28 am
A few precisions :
My flexplate is actually not flat since some ears are really touching the T/C pads whereas some others have a 3-4 mm gaps.
Is drilling the flexplate holes la bit larger a good idea? The screws really seem to lack space to engage correctly.
Thanks again,
Marc
PostPosted: Tue Aug 26, 2008 4:36 am
The pilot hole in the end of the crank, is larger then the "nub" on the converter. So the converter is not being supported. The "nub" on the converter and the hole in the crank, got larger in 1968. I would get another flexplate (68 up) that has not been bent. Then buy or make an adapter ring to fit into the end of the crank, to center/support the converter.
PostPosted: Tue Aug 26, 2008 11:01 am
I have the adaptor rings... $20.00 each, includes postage.
PostPosted: Tue Aug 26, 2008 12:40 pm
Hi everyone,
So I should get the trans out, redo the thread and then get an adapter ring.
Charlie, do you think the flexplate is that much of a problem if bent that it needs replacing?
Doc, I guess the shipping is US only... I'm in France...
What do these rings look like, do you have some blueprints you would give away? I guess no since you are selling these...
BTW, how hard is getting the trans out with engine still in? What's the best procedure?
Thanks for your help,
Marc
PostPosted: Tue Aug 26, 2008 1:55 pm
Yes, overseas shipping would be a little more.
The ring has a .125 inch wall needed to take-up the extra space between this combination of parts.
OD is 1.81 and the ID is 1.56 and it's 5/8 (.625) wide.
It is best to measure your parts so you get a light press fit to the crank's pilot hole and still have a close "running fit" where the converter's hub slides into the ID.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 1 guest
