It is currently Tue May 19, 2026 6:48 am
 Post subject: A 903 trans
PostPosted: Sat Aug 23, 2008 11:06 am
Recently removed trans to replace clutch, etc. and discovered the real problem is that the "front nosecone" (my definition) is broken. The sleeve on which the throw-out bearing rides has broken off from the flange. Is this an oem only part or can it be sourced from the after market?
Thanks - Tom Snyder
PostPosted: Sat Aug 23, 2008 4:14 pm
The part is called an input bearing retainer or IBR for short.
I would guess nobody reproduced the IBR for an A-903. It may interchange with other Mopar manual transmissions, but I'd have no idea.
What's the seven digit part number on the part? Measure the bolt circle diameter of the four bolts, too.
PostPosted: Sun Aug 24, 2008 6:33 am
I have a a 903 3 speed manual tranny with first gear syncros and a flywheel. I do not need, if you want some part or the whole thing I am located in Oklahoma City.
Joe
1964 barracuda 198 slant
PostPosted: Wed Aug 27, 2008 4:42 am
The number cast on the flange is G94781 (first digit could be a "C"). My flange has 3 bolts on 3" centers.
