It is currently Mon Jun 01, 2026 6:18 am
PostPosted: Thu Aug 28, 2008 6:16 pm
The carb rebuild kit (Walker) I bought only came with a 318 carb to intake gasket, not the super six carb to intake gasket. Will the 318 one work?
'74 Duster 225 Super Six w/904
14" Cragar SS wheels
PostPosted: Thu Aug 28, 2008 9:12 pm
Please be specific. Which gasket arrived in your kit? Describe it for us, or post a (reasonably small) picture. How thick is it? Two round holes or one big bathtub-shaped hole? End notches or none? And (exactly) what carb are you using?
PostPosted: Thu Aug 28, 2008 9:16 pm
That's the one with the notches in the side, right?
If so, i've had good luck using them as long as the surfaces are flat, and the carb is properly torqued-down and kept that way. I have not experienced vacuum leaks in the notch areas, however others may have.
PostPosted: Fri Aug 29, 2008 2:13 pm
I am using a Carter BBD. The 318 one in this pic is the one I have. Its about 1/2" thick, give or take.
PostPosted: Fri Aug 29, 2008 2:21 pm
You ought to be OK using the notched gasket.
PostPosted: Fri Aug 29, 2008 2:24 pm
Thanks! :D
Users browsing this forum: Google [Bot] and 8 guests
