It is currently Sat Jun 13, 2026 4:29 am
 Post subject: Timing belt topic
PostPosted: Fri Aug 29, 2008 10:25 pm
okay, i was told that the timing belt and gears had "nylon" in them, please discuss about them?
71 dodge dart custom
1988 Honda Civic ((Because racecar))
2005 VW Jetta
1963 AMC Rambler American 440
PostPosted: Fri Aug 29, 2008 10:27 pm
(1) Slant sixes do not use timing belts. Slant sixes use a camshaft gear, a crankshaft gear, and a timing chain.
(2) Factory original timing gears had nylon coating the teeth f the gears. THis wears off and causes slack in the tiing set of the motor.
(3) Replacement timing sets do not use nylon teeth.
PostPosted: Sat Aug 30, 2008 5:04 am
Is there anywhere that sells true roller timing chains for the slant six?
1969-1/2 Dodge Super Bee A12 (440 Six Pack, 4-spd, Dana 60)
1974 Plymouth Duster 360 (4-spd, 8.75")
1973 Plymouth Duster (225, auto, 8.25")
2001 Dodge Ram 1500 QC 2wd (5.9L, auto, Dana 60)
PostPosted: Sat Aug 30, 2008 5:09 am
Yep,
THe best are double roller. I have one new i n the box I don't need. PM me if you want it and a pic of it.
rock
'64d100
PostPosted: Sat Aug 30, 2008 7:38 am
What brand is it?
How much are you asking?
Does the /6 have it's own specific timing set or does it sare a set with the small blocks, big blocks, or any other vehicles set-up?
What manufactures produce a double row roller timing set for the /6?
Last edited by daniel_depetro on Sat Aug 30, 2008 7:53 am, edited 2 times in total.
PostPosted: Sat Aug 30, 2008 7:40 am
(1) same purpose.
(2) known.
(3) known.
still i just want to know how long it takes to replace such a nylon ..system..thingy. i heard its $30 for the replacement timing set, dunno yet, i was just suggested to replace it. I never replaced a timing chain, but i have a good ideas as to how to do it.
2005 VW Jetta
 Post subject: an afternoon
PostPosted: Sat Aug 30, 2008 7:54 am
It will take an afternoon to change, and more if you decide to do any 'optional' work... like 'degree in the cam' rather than 'line up the
dots'... and how you seal up the timing cover and how careful you are in sealling the front oil pan gasket.
 Post subject: Re: an afternoon
PostPosted: Sat Aug 30, 2008 7:52 pm
And that can be the hardest part of this job.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 4 guests
