It is currently Fri Jun 19, 2026 10:55 am
 Post subject: A slant six quandry
PostPosted: Mon Sep 01, 2008 10:53 am
I'm fairly new to all this so please bear with me. I've just bought another '65 Dart which has come with a engine and trans out of the car. It's an earlier 3 freeze plug block, I've been told it was running fine when it came out of another car a couple of years ago. The engine in my other Dart leaks like a good'un and imminently needs attention. It's a later 5 plug block.
My plan for the white Dart that's on the road at the moment is to fit a freshened up 6 with possibly some go-faster bits. The other Dart is going to be V8-ed in the end.
I've been reading up a little (as we all know a little knowledge is very dangerous!), and I understand that the 5 plug block is stronger and better to modify. However I don't really want to take the car off the road to rebuild the engine - it would be much easier for logistics to rebuild the engine already out.
I don't intend to race the white dart, it'll be a road car but I'd like to make it a bit quicker.
So, over to you guys - what would be the best engine to use for this exercise and what would you recommend I do???
Thanks
Jeff
The rules are there are no rules!
PostPosted: Mon Sep 01, 2008 11:35 am
A lot of the really fast racers (10s - 12s) have used the 3 plug block. Unless you are planning on big HP (boost, N2O, high RPMs), then I wouln't hesitate to use the 3 plug block. Either are fine.
PostPosted: Mon Sep 01, 2008 4:15 pm
i have a two 3 plug block , one is a 11.4comp 280hp 12.30et, the other is a 4-71 blown 371hp 11.85et, i have no problems :wink:
PostPosted: Tue Sep 02, 2008 6:50 am
Excellent thanks :D - at least it means I don't have a dead car rolling around while I have the work done!
