It is currently Sat Jun 13, 2026 4:38 am
 Post subject: Question About Camshafts
PostPosted: Tue Sep 02, 2008 12:20 pm
Hey guys, thanks for all input on my carb question.
I bought a Holley 390 cfm with an elec choke. I have pulled my engine apart and taken the head off and removed the intake and exhaust manifolds.
So here is the question.
The engine is a 198, I am doing the head over with stainless
steel 170/144 valves, I will port and polish the head as well, I also have
an offy four barrell manifold and Clifford headers.
After getting it apart I thought that was't that hard, lets complete the job and change the camshaft.
What would you guys recommend for this setup?
Thanks again in advance.
Wayne
PostPosted: Tue Sep 02, 2008 12:28 pm
What is your target compression ratio, car weight, final drive ratio and vision for the car?
Is it a standard?...convertor stall? Premium fuel?
PostPosted: Tue Sep 02, 2008 12:33 pm
More info needed.
How "choppy" of an idle can you stand?
PostPosted: Tue Sep 02, 2008 12:41 pm
It is a 1970 Valiant 4 dr three speed standard. I will use it only on the street and not really push it too hard. I just wanted to wake it up a little and get some looks at the car shows. I can stand a fairly lopey idle with the standard trans. Not too sure about the weight of the car it is all stock on the body parts. Thanks
PostPosted: Tue Sep 02, 2008 12:43 pm
OOPs forgot it has the 323 axle I beleive which is stock with my configuration.
Users browsing this forum: Ahrefs [Bot] and 3 guests
