It is currently Sat Jun 13, 2026 5:44 pm
 Post subject: Lapping compound
PostPosted: Thu Sep 04, 2008 11:29 am
There's a good possibility I'll be pulling my head this weekend.
Doc, you suggested a lapping compound for touching things up before reassembly.
I spaced the name/brand you suggested. Could you share it again here?
Thanks!
PostPosted: Thu Sep 04, 2008 11:41 am
I knew You had some screws loose but it is not necessary to go THAT far :shock: :shock:
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Thu Sep 04, 2008 12:02 pm
Clover lapping compound.
See this link for info and the different grades:
http://www.newmantools.com/clover.htm
PostPosted: Thu Sep 04, 2008 3:02 pm
Thanks Doc!
For this application I would think 320 would be the stuff. Is that what you would use?
PostPosted: Thu Sep 04, 2008 3:30 pm
6 Pack Dart
I've got some, see you this weekend.
PostPosted: Thu Sep 04, 2008 3:44 pm
The 320 "Fine" compound works great.
You should not need a lot to get the impression you need to see full seat contact.
If the valve angles are off, your machine shop should correct the problem.
