It is currently Thu Jun 04, 2026 3:49 am
PostPosted: Wed Sep 03, 2008 12:59 pm
I had a conversation at work last night with a gentleman who works for a copper company here in the 'burgh. His company has a division that makes Head gaskets (copper) and Connecting rods(aluminum).
Anyway I was curious to see if I were to have the Steel shim Head gasket replicated in copper would that be of interest to folks on the forum?? I would shoot for the same compressed thickness. Please share your Thoughts and What is the correct compressed thickness of the Original steel shim gasket?
I have no Idea of what price would be? So Share what you would be willing to pay for such a gasket.
PostPosted: Wed Sep 03, 2008 1:23 pm
Cox Brothers offered a .030" and a .040". Around $100.
Tom
PostPosted: Wed Sep 03, 2008 1:32 pm
Before you go too far, we should talk. I am interested in getting Cometic to make MLS (multi-layer steel) head gaskets suitable for alum and iron Slants. SSDan made inquiries about this 1-2 yrs ago.
SCE still makes the copper gaskets, I think.
These would be as good or better than copper and would suit many applications, incl boost.
I need to call Cometic and find out where we need to go here.
PostPosted: Wed Sep 03, 2008 1:42 pm
I have never used a solid copper head gasket but have been told that they tend to leak coolent.
Most of the racers using a solid copper head gasket have the block o-ringed to maintain good compression - cylinder sealing and use other sealers to keep the coolent from 'sneaking-out' past the gasket.
PostPosted: Wed Sep 03, 2008 2:16 pm
Car Model: 1964 Valiant V200
I've used copper gaskets in air-cooled motorcycle engines and even then there are a lot of pitfalls. First, the surface of the head & block has to be PERFECT - no texture at all. Second, they will all eventually leak no matter what you do.
Summary: unless you're talking VW or Corvair where the gasket is a simple copper o-ring, don't waste your time.
PostPosted: Wed Sep 03, 2008 2:46 pm
I used the Cox Bros (SCE) head gasket. My block was "O" ringed, and the gasket was coated with Permatex "hylomar" sealant. I ran that motor about 3 years, with no gasket problems, or coolant leakage, but it was not a daily driver.
PS when I replace the pistons (three broken), I intend on reusing the same gasket.
PostPosted: Wed Sep 03, 2008 4:29 pm
I have a copper head gasket on my current engine. I o-ringed the block and used a material called hylomar to seal up the water. It leaked on the first startup but has not leaked since.
I'd like to go the Lou route with a MLS but will have to stick with copper in the mean time.
PostPosted: Wed Sep 03, 2008 6:56 pm
Ok good info there.
I Have never run a copper Head Gasket and Have Always run either a stock Steelshim or A felpro with no problems.
PostPosted: Wed Sep 03, 2008 8:07 pm
I know plenty of guys that use them successfully with o-rings in highly boosted Mitsubishi turbo engines but they tear them down pretty often. I also know guys that can't get them to seal even with orings. Bigger bores have more problems (less space between fire rings).
PostPosted: Thu Sep 04, 2008 8:58 am
I talked to Cometic last year at PRI - they said they'd need a pretty large order to justify the cost of the tooling. It would either take a slant six part company placing a bulk order or a very large group buy.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Thu Sep 04, 2008 12:43 pm
Interesting. I wonder what "large" means. They say they do custom gaskets on their site, so maybe that's bunk?
I would guess $80-150/gasket would be reasonable and I'm sure we could sell 20 gaskets right away.
PostPosted: Thu Sep 04, 2008 1:22 pm
The Guy I was talking to About the copper stuff said they Do the Head Gaskets with a CNC Waterjet MAchine.. So There is not a lot of tooling setup there.
PostPosted: Fri Sep 05, 2008 7:27 am
The number I seem to remember was 50 to 100.
PostPosted: Fri Sep 05, 2008 7:40 am
If I have a spare $10k sitting around, I'd rather have an alum head... :?
A lot of the "tooling" might cross over to 2.2L/2.5L or 2.0/2.4L gaskets they already make. Other apps they make have ~88-89 mm bore size too.
I'll still call them.
PostPosted: Tue Sep 09, 2008 10:20 am
I have gotten a copper head gasket from the Coxes. Befor they carried them I have used gasket shops from the back of national dragster. I have never found a copper gasket shop that did not have a template or complain about making me one. But the Coxes have one on the shelf...
Will
