It is currently Tue Nov 24, 2026 12:41 am
 Post subject: Exhausting
PostPosted: Mon Sep 08, 2008 5:10 pm
Hi,
I would like the collectives opinion....I am ready to do some mods to the '72 Valiant. Its a street car with projected HP of 225 to 250 at the flywheel. I am only making 80 at the wheels now so I figure my goal should make for a fun driver. I'm using Dutra duals because they make more sense for the purposes of my car. I was at first going to run full duals but have decided it's overkill and will add uneeded weight. I am going to run a DCE (driver controlled exhaust) muffler. It enables the driver to drive in quiet mode using the muffler as it is intended and has the capability to bypass part of the muffler and allowing more exhaust flow and noise in the process . The rest of the exhaust will be the same as stock except the diameter can be changed to suit my needs. I was thinking 2.5" for the entire system. What do you think? too big? One more thing where is the best place to mearge the two pipes that come off of the Dutra duals ? thanks for the help...nico
PostPosted: Mon Sep 08, 2008 10:42 pm
Go Full Dual all the way ala V8
With either an X-pipe or H-pipe Crossover
As to Diameter 2 1/2 should be fine Doc? :?
Single system 2 1/2 but not certain about dual
:lol: WE ARE THE SLANTERS RESISTANCE IS FUTILE!
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
 Post subject: Re: Exhausting
PostPosted: Tue Sep 09, 2008 6:00 am
I'll be VERY curious to hear how well this works... Please keep us posted.
vm
PostPosted: Tue Sep 09, 2008 6:54 am
Car Model: 1964 Plymouth Valiant 225, 1977 Dodge D100 225
As am I. This sounds like a very interesting form of muffler.
Chuck and the Flying Valiant
PostPosted: Tue Sep 09, 2008 9:03 am
I have run a number of different exhaust systems with the Dutra cast iron manifolds and had the best results with 2, two inch pipes off the manifolds, collecting into a 3 inch collector that reduces to 2 1/2 pipe back to the muffler. A 2 inch tailpipe from the muffler to the back of the car or a 1 7/8 tailpipe if you want even less noise.
If you decide to run dual pipes all the way back, be sure to use a "cross-over" or else the harmonic drone will drive you crazy.
PostPosted: Tue Sep 09, 2008 6:21 pm
Thanks everyone! for the reply...If anyone is interested in this muffler (DCE = driver controlled exhaust), I can provide contact info for the company that sells them. Also Doc, ideally, where should the two pipes from the manifolds be mearged? Thankyou, nico
PostPosted: Wed Sep 10, 2008 5:23 am
and dont froget a good set of glass packs
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
