It is currently Sun Nov 22, 2026 4:43 am
PostPosted: Fri Sep 12, 2008 12:33 am
Hello all, Ive got a 65 valiant 2 dr. and the previous owner painted the entire car including over the roof rail weatherstripping (or is it called drip rail?)
Where some of the paint is removed, the weatherstrip is crumbly and old...anyone know how to replace this stuff and where to get it?
Would self leveling seam sealer work?
I thought I should ask before I start removing it
thanks!!
PostPosted: Sat Sep 13, 2008 6:55 pm
Are you talking about the rubber weatherstripping under the drip rail? Like this: http://nicksclassicparts.com/New%20Page ... ipping.htm
The reason why I am confused is that you mentioned self leveling seam sealer that is used on top (if you will) of the roof rail.
Chris'
Autobody
Restoration
Service
PostPosted: Sun Sep 14, 2008 12:21 pm
Ahh, it looks to be the stuff used above the roof rail
Any recommends?
thanks!
PostPosted: Mon Sep 15, 2008 11:56 am
You can either use self-leveling seam sealer or the traditional seam sealer. With the traditional "caulk" type you will have to smooth it out by applying thinner or reducer to your finger and wipe it smooth.
It's kinda hard to describe how to do it so practice on something else first.
Chris'
Autobody
Restoration
Service
