It is currently Sun Nov 22, 2026 5:50 am
PostPosted: Fri Sep 19, 2008 3:02 pm
Hi all
I did a search and couldnt find the awnser so here it is.
My fuel pump gasket is the source of my oil leak. I am going to replace the gasket tonight. I have never done this before. Is there anything I need to be aware of. It looks simple enough. But looks can be decieving.
Thanks
This is my Signature
Russ Stanley
PostPosted: Fri Sep 19, 2008 3:27 pm
Make sure you get all traces of the old gasket off both the fuel pump and block surfaces, and make sure you get the fuel pump arm riding on top of the camshaft, not hooked under it. If you find the pump springs away from the block as you unbolt it, rotate the engine by hand or with quick bumps of the starter until the cam lobe moves inward, or it'll be impossible to install the pump correctly.
PostPosted: Sat Sep 20, 2008 5:25 am
Dan is right . Also helps to use fuel line wrenches instead of open end.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sat Sep 20, 2008 6:11 am
and of course, no smoking!
other than that, the guys have everything covered!
:wink:
There`s a sticker on my car that says!
Somwhere in texas, there`s a village
missing it`s idiot!
you know what, it`s the truth! hehe
PostPosted: Mon Sep 22, 2008 5:09 am
Thanks guys
I had it off and back on in about 20 minutes.
Russ Stanley
