It is currently Tue Nov 10, 2026 1:16 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Tue Sep 16, 2008 12:30 am
Got my gas gauge working, it was a hole in the float(full of gas, to heavy) that made the gauge read empty, plus when you have enough gas out of the tank, so you can take the sending unit out, i found that it was not enough gas to even register on the gauge......just a little info.
Also added a better ground, that ground strap is not good enough....for the years on the car.
1973 Dodge Dart Custom
PostPosted: Sun Sep 21, 2008 9:37 am
Does any one know if you can buy just a replacement float? Would have to be a lot cheaper than buying the whole sending unit, if yours checks out o.k.. Thanks
74 2 door dart. All stock, work in progress!
PostPosted: Sun Sep 21, 2008 10:59 am
If your float is brass, one can solder it to make it air tight. Remove all the gasoline & vapor from the fuel logged float before soldering on it.
