It is currently Wed Jul 15, 2026 8:59 am
Post new topic  Reply to topic  [ 296 posts ]  Go to page Previous 15 6 7 8 920 Next
PostPosted: Sun Sep 21, 2008 10:56 pm
Smokin! Nice Job!
Can you do a quick run down on the combo as it is today? I haven't kept up with the changes.
 Post subject: Re: Went Racing Again!
PostPosted: Mon Sep 22, 2008 6:01 am
Today was a good day for the Valiant! All I did from the 12.00 combo was put on the different turbo and a bigger #10 meth jet and it turned a 11.588 @ 115.66. This is still at 16* total timing and washer fluid blend. I changed to 100% meth and went to a 11.556 @ 116.23. We had a long rain shower so the sun was setting as I ran the final run which is the best ever.
60' - 1.639
330' - 4.710
1/8 - 7.311
mph - 93.84
1000 - 9.565
1/4 - 11.487
mph - 116.92
I must say the 100% Meth didn't help the ET much but it dropped the A/F from 13.3 to 12.2. Over a full point richer. I would still like to see it closer to a mid 11 though. I stayed with miner changes today to do some real comparisons. Still 22 psi and primaries only. It still has the bunny hop but the best 60' today went down to a 1.60. Although not on my best run. Had alot of fun today with this Slant getting lots of attention!
Later.
Get them 2nd-dairys open & working!....Even though you didn't see an ET change with the meth, it looks like you did see a MPH increase. Small but still an increase (this tells the HP increase, not the ET) and like you said...an improvement in the AFR.
Way to go, VERY nice numbers.
PostPosted: Mon Sep 22, 2008 8:10 am
Wow. Keep up the great work!
We are scheming for a central US race location for next year or two to get West and East racers to meet up. KS, NE, or SD would be good places to think about...
PostPosted: Mon Sep 22, 2008 9:13 am
Have you tried to work with the secondaries? Have you tried another carb?
PostPosted: Mon Sep 22, 2008 8:24 pm
Thanks guys, Never thought it would be this fast this year. A race fairly close would be great. I sponsor the Sportsman Class here at Oahe Speedway w/ Amsoil Synthetics so I do have some pull here at this track if you guys would like it this far north. They are really open to ideas like this. Let me know if I can help out.
Here is a quick run down on the combo:
Standard bore 225 (swather) stock deck ht, stock crank, bearings & oil pump (45 psi), all 1972 vintage.
TRW Forged w/ speed pro moly rings
Comp cams pushrods
Dual springs w/ e-bay stainless 1.70 in / 1.44 ex
1970 head - uncut surface (just cleaned), Bowl port, no gasket match
Erson turbo cam & lifters - 114 lobe sep - installed at 101.5 (rec at 110)
Stock computer controlled Dist (no weights) - 16*
Orange box w/ MSD blaster coil and wires
Custom Header w/ 3" turbo inlet and 3" outlet
Garret T70 Turbo w/ stage 5 wheel - .58 hot - .70 cold - P trim
Greedy BOV - China wastegate
Divided carb bonnet
BG Demon BT 575cfm - only using 1/2
Devils own Meth w/ 100% meth - #10 jet
Ebay intercooler and plumbing
GER 4000 stall
727 trans - Manual Valve body
Stock rebuilt susp w/ drums on all 4 (4" bolt pattern also)
8 3/4 3.23 spool
Aeromotive A1000 pump and boost reg w/ return and cell
Amsoil 20w50 racing oil - Amsoil Super Shift (trans) - Amsoil 75w90 Severe Gear in rear
26x8.5x14 ET Drags
I hope this helps if someone else out there is contemplating a turbo build. I shift at 5500 and traps are 5500. It took a few years of collecting parts on e-bay and jegs to get a list like this. Later
Ryan
PostPosted: Tue Sep 23, 2008 6:09 am
Hey Ryan
How come so thick an oil??? I would think you could pick up some speed with a thinner oil and if you turbo is oil cooled wouldnt it like thinner oil as well??
Thanks for all the updates we enjoy watching your build,
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Sep 23, 2008 6:41 am
60' - 1.639
330' - 4.710
1/8 - 7.311
mph - 93.84
1000 - 9.565
1/4 - 11.487
mph - 116.92
Wow, very good numbers :D Are you going to dyno the engine?
PostPosted: Tue Sep 23, 2008 9:22 pm
Hey Frank,
I have tried 10w30 petroleum and synthetic in this car and the 20w50 seems to keep the engine temps alittle lower. I had heard about quicker spool with a lighter oil but it didn't work for me. Also, the added (not noticable) hp you get with a lighter oil to me isn't worth it. I figure if I'm puting just under 2 HP per cubic inch, the best insurance is the best oil I can get. I've used the Amsoil Racing 20w50 for years in all my performance cars from 2.2L turbos, small blocks and bigblocks with no problems.
I would like to get it dynoed sometime but the closest chassis dyno is 2 1/2 hrs away and $100 per hr. Later
PostPosted: Wed Sep 24, 2008 6:19 am
Done blame you there. I would also go with what works...WOW 20-50 in a 2.2 Can we say windage. LOL
You certianly have a BOSS ride.
Frank
PS Keep on RACIN :lol: :lol: :lol: :twisted:
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Sep 29, 2008 2:10 pm
I am in the process of starting a turbo /6 setup in my 65 Dart. With that said I cannot comment on your setup but will say i had problems on a few beetles that where blow through that just did not like any boost over 8 psi on a vac secondary carb. It would actualy move the secondary flaps under boost and gave us fits.. Changed it to a manual secondary carb and not a problem. This is with the boost refernce in the proper location.
Oh and by the way.. Nice setup.. I am going to do a front mount with my dart as I want to keep it looking like grannys car..
Steve
37 Plymouth
62 Lancer GT
PostPosted: Mon Sep 29, 2008 9:06 pm
I was originally thinking on a vacuum secondary carb (saw a few big wigs using them) but choose this Demon double pumper instead. I'm glad I did, I just need to get the bugs worked out of it yet. I haven't worked on it for a month or so. Goodluck with your build and send some pics. Later.
Ryan
PostPosted: Sat Oct 04, 2008 6:56 pm
What a great read!
I found this doing a search for info on a BG 575 blow through carb.
I'm in australia and in the process of turboing my 1970 Holden LC torana.
I've got a 202ci straight 6 (very similar to a chev inline 6).
I would love to get into the 11 seconds! But its gonna be a while till the old girl is all back together, in the process of starting a bare metal respray aswell!
I'm leaning towards a the 575 carb, unless someone can give me a better option for around the same price.
Finding a read like this gives you that inspiration you need to keep at it!
PostPosted: Sun Oct 05, 2008 5:10 pm
Sweet, I love it. Glad your inspired even though it isn't a Slant 8) . I tried the secondaries the other day and they worked. The bigger cube seems to pull the fuel thru better. I guess I'm pretty happy with it now. Added 3 more psi of boost and the #14 meth jet and she flat scoots now. Running mid 11's on the A/F also. My closest track is closed for the year, I'd really like to post some quicker ET's :D It's so tempting with boost you know. Later.
Ryan
PostPosted: Thu Nov 27, 2008 3:05 pm
Here are some updated photos of the engine bay.
PostPosted: Fri Apr 03, 2009 3:43 pm
Things added this spring are:
Slide-a-link rear suspension
Rear tubes and bolted slicks
Things to do this week:
Roll bar, seat and belts
Alum Radiator and hoses
Calvert front shocks
Later
Ryan
10.74 @ 127.47 mph 1320 ft
6.65 @ 107.80 mph 660 ft
http://www.youtube.com/c/turbo66valiant
Follow on Instagram - turbo66valiant
Facebook - https://www.facebook.com/ryan.peterson.737
Users browsing this forum: Amazon [Bot] and 1 guest
