It is currently Fri Nov 27, 2026 2:37 pm
Post new topic  Reply to topic  [ 91 posts ]  Go to page 1 2 3 4 5 … 7 Next
PostPosted: Tue Sep 23, 2008 9:26 pm
OK You guys all have seen this one that is busy being recreated
And Maybe this one which is also in line for recasting
But I BET you haven't seen THIS one - I had Immediate requestes for recasting this as well....
Always something new from Africa Hey 8) South Africa at Least - we have even just fired our president
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Tue Sep 23, 2008 9:33 pm
Looks like the middle runner runs under the other 2 to get equal length.................
PostPosted: Tue Sep 23, 2008 10:48 pm
Why do you taunt us? :x
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
PostPosted: Tue Sep 23, 2008 10:56 pm
Why OOOH I dont know - I am a cruel man - orders please :D
Regards,
Fanie Gerber
PostPosted: Tue Sep 23, 2008 11:47 pm
The nice thing is that this seems to be a kind of "DUAL plane" design and the split area in the middle is precisely the position the Butterflies on the 36DCD Weber is aiming at - these carbs focus their barrel flow to the middle position - the butter flies open towards each other and the middle and this is a progressive carb - the DGAV is similar cheaper but not as tunable
Regards,
Fanie Gerber
PostPosted: Wed Sep 24, 2008 5:51 am
Any plans to put EFI bungs on any of those? That would be a nice selling point.
PostPosted: Wed Sep 24, 2008 6:09 am
Amen. I was hoping to pick up one of the new Aussie manifolds for that very reason, but I decided the size of the manifold would interfere with my power brake master cylinder. These designs seem shorter, and better for my F.I. plans.
vm
PostPosted: Wed Sep 24, 2008 6:55 am
Your wish is my command - we still have some fiddling time
How far from the runner opening , what diameter and at what angle to the runner centerline do you want them
The Request so far has been
Water heated plenum for all
EFi Bungs
Bracket kit for the dualies
Plenum Divider for the 4BBl
2bbl & 4 BBl Mounting plates with the carbs rotated 90 degrees
please ad on to the list while there is time and we will see what is feasible
BTW the ruler next to the manifolds are 30cm
here is pic for comparison sake with a supersix type manifold
Regards,
Fanie Gerber
PostPosted: Wed Sep 24, 2008 8:59 am
Your wish is my command - we still have some fiddling time.
Since my fuel injection plans are still at the "someday" stage, I'll defer to the EFI guys here...
vm
PostPosted: Wed Sep 24, 2008 9:43 am
I'd say put them at 45 degrees to the runner and have the top of the injector pad about 2 cm above the runner and 1.5 cm back from the manifold flange. The way Clifford did it should work well. Pad should be at least 2 cm wide, 2.5 cm is better, and centered on the runner.
You do realize you'll have competition from the Aussie "Hurricane" intakes just made available, at least for US and overseas buyers.
Best,
 Post subject: compitition
PostPosted: Wed Sep 24, 2008 9:50 am
a little competition is good 8)
63 valiant v200 Wagon 9.5, Schneider cam, E.I. 22 mpg all day
PostPosted: Wed Sep 24, 2008 10:53 am
Oh well I am doing it because these manifolds were original options available on your chrysler from the dealer - These are more for the restification performance enthusiasts - and due to reasonable pricing on the manufacturing side my manifolds will retail for $250 ish
First 10 orders on each for $175 :D
Regards,
Fanie Gerber
PostPosted: Wed Sep 24, 2008 11:15 am
Best,
That sounds good to me too.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Wed Sep 24, 2008 11:34 am
$175 for the long dual carb intake? I'm in for one!
PostPosted: Wed Sep 24, 2008 1:41 pm
You had me talked out of the offy 2x1 a month ago for your dual weber and then you go and add a dual plane dual weber to the mix :twisted:
Too many choices here! You posted an article about the dual weber swap a while back in the Offy group buy thread (I think), any info or data on the dual plane dual weber???
BTW, adding EFI bungs to all intakes is a great idea if you are still in the forming stage. If someone doesn't want them until later, they have options. If someone just wants the intake for an original reproduction they can be "massaged" off the intake.
Chris'
Autobody
Restoration
Service
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 4 guests
