It is currently Sat Nov 21, 2026 6:58 pm
 Post subject: Crankcase Breather
PostPosted: Thu Sep 25, 2008 10:18 am
I have a 71 Duster 225 an was wondering if anyone knew where I could get a stock replacement crankcase breather. The one on the vehicle has provisions for two hoses, one to the air cleaner housing and the other for the fuel tank gases. Thanks
"You know a car is really yours when you've touched every fastener on it." -David Freiburger
PostPosted: Thu Sep 25, 2008 11:21 am
These can't be had any more, but there's a workaround. See this thread.
PostPosted: Thu Sep 25, 2008 12:04 pm
Thank you sir
PostPosted: Fri Sep 26, 2008 5:59 pm
Dan, do they sell the grommet for the crankcase breather?
PostPosted: Fri Sep 26, 2008 7:32 pm
Yup, used on just about all RWD Mopars from '70 through at least the early '90s.
PostPosted: Fri Sep 26, 2008 7:51 pm
The grommet that connects the breather to the stock valve cover is Dorman #42344
That goes in the 1.5" valve cover hole and reduces it to 1" for the breather.
