It is currently Sat Nov 14, 2026 5:30 am
 Post subject: Coil
PostPosted: Thu Oct 02, 2008 9:38 pm
I recently installed a Chrysler type electronic ignition conversion kit and was wondering what a good coil would be for the new system. Thanks
"You know a car is really yours when you've touched every fastener on it." -David Freiburger
PostPosted: Fri Oct 03, 2008 8:08 am
Hi there. Please see this discussion.
PostPosted: Fri Oct 03, 2008 8:35 am
Like Dan said in the referenced post, get a coil designed for electronic ignition. When I converted my '72, I used the stock points type coil. Lasted about a week. When I went to the parts store to get a new one, the parts guy asked me if it had points or electronic. Apparently there are two types. Currently I use a MSD Blaster II with their .8 ohm ballast resister.
PostPosted: Fri Oct 03, 2008 1:33 pm
Thanks Eric W
