It is currently Thu Nov 19, 2026 8:53 pm
 Post subject: Oil Pump replacement
PostPosted: Fri Oct 03, 2008 8:03 pm
Can someone explain the process of replacing a slant six oil pump?
I found a Melling 66C for $20 and am thinking about doing it myself. But I've never done this before. It looks like a couple of bolts, a gasket and putting it in the right spot.
Thanks.
60 Red V200 Valiant & 62 Green V200 Valiant
PostPosted: Fri Oct 03, 2008 8:46 pm
Thats about it,5 bolts(old ones had 6) clean the block real good,use some gasket goo on the pump/gasket(keep it from moving wilst installing).Wouldn't hurt to use some assembly lube on the gear,install in reverse order of removal,pour a little oil in before install an rotate the gear some make sure it's lubed and a bit more after install.I don't use gasket goo on the block side.Good luck
PostPosted: Fri Oct 03, 2008 8:54 pm
Oh yeah and 200 inch pounds of torque :wink:
PostPosted: Fri Oct 03, 2008 9:42 pm
Not to mention that unless it's in a truck, you will need to undo the motor mounts and raise the engine quite a bit to get clearance to pull it out.... unless the motor is already out. :D
~THOR~
PostPosted: Sat Oct 04, 2008 8:06 am
Well, sounds like a bone head like me can handle that. :lol:
PostPosted: Sat Oct 04, 2008 9:29 am
6 Pack Dart
You might want to check with Doc about the drive gear on the new pump most of them are soft and will get chewed up.
