It is currently Tue May 19, 2026 11:22 pm
 Post subject: Removing a pilot bearing
PostPosted: Sun Oct 05, 2008 6:20 pm
Any genius tricks out there for getting a bushing out?
I got a puller, but it won't do the job. Too short.
Thanks
 Post subject: Cold chisel
PostPosted: Sun Oct 05, 2008 6:49 pm
You need the longer puller (Harbor Freight)...
Your next best bet is to use a cold chisel, but make sure not to scrape the pilot bushing bore in the crank...
-D.idiot
PostPosted: Sun Oct 05, 2008 6:58 pm
Pack the hole with grease. Get a steel shaft that is the same size as the I.D. of the bushing. Insert the shaft into the bushing and hit it with a hammer. Hydraulics pushes the bushing out.
Or am I missing something…
Danny
 Post subject: Re: Cold chisel
PostPosted: Sun Oct 05, 2008 7:10 pm
-D.idiot
This one is from HF. Are you saying Harbor Freight has two lengths of bushing pullers?
Thanks
 Post subject: ???
PostPosted: Sun Oct 05, 2008 8:00 pm
I had bought one 5 years back and have used it only a couple of times and it worked great, a buddy got a new one and it looks a bit shorter on the pulling prongs... you can do the hydro trick previously explained as long as the bushing isn't loctited in... the old standby trick of scoring a cut down the middle of one side of the bushing then prying on it with an awl to roll the side over and pulling out with a pliers is the old shade tree mechanic way to go.
PostPosted: Mon Oct 06, 2008 5:10 am
Danny
I have found this is the easiest/best.
 Post subject: Re: ???
PostPosted: Mon Oct 06, 2008 11:21 am
The "hooks" extended from the tips to about 3/8 inch. And the upper arms were about that thick as well. I took an angle head and a dremel and reshaped the profile. Got the hooks down to about 5/32 inch and the arm thickness down to about 7/32 inch. That worked.
I couldn't use the hydro method because the bushing was mis-shapen badly. After I got it out I could see that I could have knocked it out easily enough, because it was pretty thin and very brittle.
Thanks
PostPosted: Mon Oct 06, 2008 11:23 am
Danny
By the way, what actual evil besets a transmission when the bushing gets worn?
Thanks
PostPosted: Mon Oct 06, 2008 2:41 pm
Danny
Thanks
The input shaft can become worn and if the input bearing is also loose or sloppy, you're going to wear the needle bearings much more quickly than if all was tight.
PostPosted: Tue Oct 07, 2008 7:36 am
Since I don't know the guts and function of a transmission intimately I can only guess. Does that mean it will jump out of gear? Leak? Wear out the gear teeth?
I've always known wear is bad, but I'm trying to get a handle on what actually results from a bad pilot. I read in one place that a transmission MUST be centered on the crank within .0001. A little hard to buy. Facts are hard to come by.
Thanks
PostPosted: Tue Oct 07, 2008 10:25 am
Lakewood says that up to .005 of run-out is OK.
http://www.lakewoodindustries.com/pdf/b ... cedure.pdf
I try to keep it within .002
.0001 would be hard to get. (or measure for that matter)
