It is currently Sun Nov 15, 2026 10:44 am
 Post subject: Guzzi car
PostPosted: Mon Oct 06, 2008 9:56 pm
Will be in Redding,first time out with the Guzzi car,wondering if a 150 rear wheel hp,2450lbs car can get into the 14s,whats your thoughts?mark
PostPosted: Mon Oct 06, 2008 11:02 pm
150 RWHP? It should. All it needs to do is hook up!
It'll be good to see you Mark! :D
PostPosted: Tue Oct 07, 2008 5:18 am
My calculator says 15.1 @ 90 MPH, but I bet 14s are possible.
150 RWHP is exactly what my '68 Dart is making right now, which is good for 16.30s in my 3150 lb car (w/o me).
PostPosted: Tue Oct 07, 2008 9:02 am
That will be a good heads-up race with the other "twin"... as long as I keep the bottle turned-off. :twisted:
PostPosted: Tue Oct 07, 2008 8:57 pm
front off motor,going to re check cam timeing,if its off alot,will re time the 270 cam thats in it,if not,I want more cam,whice one?I WILL BE IN REDDING,mark
PostPosted: Tue Oct 07, 2008 10:11 pm
When on the dyno,my max hp 150 was at 3150 then flat lined,or went down a little to 5500.was a little rich but not alot,torque was 261 at 3000.confused,mark
PostPosted: Tue Oct 07, 2008 10:15 pm
Are you showing up as
flatblack
or
satinblack
:wink:
PostPosted: Tue Oct 07, 2008 10:23 pm
I will put a coat of atf on it before i get there ,so it will be satin black,just like you saw it,nice meeting you,wish you were going to redding,mark
PostPosted: Wed Oct 08, 2008 6:17 am
You need a bigger cam, or definitely retime it. Sounds like it is very far advanced. Put it in at 102 deg with that compression.
A good cam for 10:1+, which you have, would be a RDP grind, something like a 234@0.050" intake and 226 exhaust. See if Erson will do this for you. Use LSA of 106 and centerline at 100 deg.
You have a high stall converter, right? How much?
You should be making at least 170 RWHP and more like 200 if your headwork/induction is good and you have 10:1+. 150 is what my '68 Dart with stock cam and 8.8:1 comp makes on 89 octane gas.
PostPosted: Wed Oct 08, 2008 7:33 am
10.7 compression,3500 8 inch converter,bigger valves,and alot of head work,running 100 octane,will re time it to 102 if its off,dont have time to do cam swap,mark
PostPosted: Wed Oct 08, 2008 8:06 am
What induction and headers again? Thanks.
Retiming cam will probably help a lot. Actually, if you aren't going to swap it, then retard it more to 103 - 105 deg. Sounds very much like you are way advanced and the power is rolling over very low because of that.
Other problem could be timing or carb??
PostPosted: Wed Oct 08, 2008 8:34 am
My motor at that compression hates 100 octane too. It will kill a tenth or more. I welded the advance slots halfway shut so I can run lots of initial and limit total to 25-30* :shock:
PostPosted: Wed Oct 08, 2008 9:05 am
You guys are "spot-on"...
We already shortened-up the distributor's advance to stop the major pinging Mark had when the engine first ran.
An yes, the cam is advanced, intalled at 110 intake centerline... with a tight timing chain. We were hoping it was going to retard it's self a bit with use but it looks like that was "wishful thinking" on my part.
PostPosted: Wed Oct 08, 2008 10:48 am
110 deg sounds very retarded to me - do you mean 100?
After my recent cam experiences, I wouldn't dream of installing anything at over 104 deg, and 100 seems about right. That engine needs more top end, so I recommended 104 for Mark.
A bit confused...
PostPosted: Wed Oct 08, 2008 11:09 am
My bad... the cam is ground on 110 lobe centers, it installed at 101 intake centerline.
The timing gear set in this engine is way off so we had to use an 6 degree off-set bushing, to retard the cam, just to get to 101 :shock:
Looks like Mark will have to take the bushing out all together and just push the cam's pin up to the "retard side" of the oversize bushing hole, then check to see if that gets him a better reading.
Users browsing this forum: Google [Bot] and 10 guests
